will this rear blade work for my 1715?
   / will this rear blade work for my 1715?
Thanks for the info Axle. I built a platform out of 5x6" wood that I can stack weight on and then slide my Carry All under it. I can go from the 84lbs the carry all weighs up to 500lbs if I use all the weight I have to add. I'll probably add some fluid to the tires before winter so if I'm using the rear blade I have extra weight for traction.
   / will this rear blade work for my 1715? #12
Anyone ever try filling their tires with mercury? I calculate you'd add over 900# per tire versus just 90 with Rim Guard or 70 with washer fluid.
As toxic as mercury is I doubt you'd find anyone to put it in your tires. Imagine the problems you'd have if you sprang a leak and the wrong person found out about it.
   / will this rear blade work for my 1715? #14
Interesting idea but I would imagine 100 gallons of mercury would raise some flags lol.
When I was a kid someone broke a mercury thermometer in a classroom, they shut that room down for 3 days while a clean up crew did whatever they do for a mercury spill. Now think of losing 20-30 gallons of mercury if a tire got punctured, the ground would prob be classified as a toxic waste site, crazies would sue you because you hurt the environment ext ext. that would be the worst idea ever for a political, health and liability aspect, great for a ballast lmao!
   / will this rear blade work for my 1715? #15
To handle mercury requires a special licensing. To sell it or buy it is very tightly controlled and highly restricted and tracked for several reasons including environment and terrorism (mercury switches). In addition - rubber is effected by mercury. Now gold on the other hand is readily available lol.
On a more serious side - I knew someone who tried lead shot - but the results weren't that serious LOL.
   / will this rear blade work for my 1715? #16
Actually I read somewhere that someone used lead shot as the aggregate to make concrete for a set of the fill-your-own wheel weights. I don't recall off-hand the weight, but it was significantly more than gravel.
   / will this rear blade work for my 1715? #17
Has anyone put a front weight bracket on their GC1700? I see MF makes the suitcase weights for it, keen to do this for mine for when i'm pulling my box blade and/or harrows on the fields for better front traction. Although if that didn't work I'd just swap my R4's and get ag tyres.
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
CATERPILLAR 20" PIN ON BUCKET (A52707)
CATERPILLAR 20"...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
John Deere 5103 (A53317)
John Deere 5103...
2024 CFG Industrial KRW232 Mini Wheel Loader Skid Steer (A55851)
2024 CFG...
296385 (A57192)
296385 (A57192)
