Will this work on a TC24DA?
   / Will this work on a TC24DA? #11
</font><font color="blue" class="small">( I counted at least 12 hoses in this pic and I'm not sure where they would all go )</font>
From the original post. I also counted 12 hoses. There are some behind others. There are also 12 hose connections on those diverters, 6 on each that are clearly marked and visible.
MadRef,
On that Eaton-Cessna valve which should be here in a couple of days, a question.
The PBYD off the loader is 3/8" line. Normally this is hooked to another 3/8" line via quick connect to supply the 3pth. When the BH is attached it connects to this QC and too is supplied with a 3/8" line and has a 1/2" return to tank line.
Question is, would I be okay with 3/8" supply to Eaton valve, 3/8" PBYD back to 3pth, 3/8" cylinder lines and 1/2" return to tank from Eaton valve?
   / Will this work on a TC24DA? #13
Many hydraulic shop professionals use the next biggest size for the return to tank line. My guy does. It is not a pressure line so bigger will not matter.
However, I and others (ie Jinman) recommend 1/4" hoses for the TNT connections from the aux valve work ports. The slightly restricted line will give more precise feathering capabilities. I also makes it easier to plumb.
   / Will this work on a TC24DA? #14
</font><font color="blue" class="small">( Many hydraulic shop professionals use the next biggest size for the return to tank line. My guy does. It is not a pressure line so bigger will not matter.
)</font>
Or simply add a inexpensive restrictor to slow things down a bit.
2019 Chevrolet Tahoe SUV (A55973)
2019 Chevrolet...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2008 International 7500 T/A Altec A77T 76ft. Bucket Truck (A55973)
2008 International...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
2014 Chevy Malibu Sedan (A56859)
2014 Chevy Malibu...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
