Winch Valve ?
   / Winch Valve ? #21
OK, so I guess you don't need the pics. Your truck has a PTO on the front diff? IMO, you'd be better off looking at a Milemarker and selling what you've got. That winch would be ideal on a tractor. When it all shakes out, you'll be close dollar-wise (and you'll have an extra 2500lbs of pull). A general rule of thumb is that the reservoir should be at least the same volume as required per minute. So you need at minimum a 15gal reservoir and then a 15gpm pump...
   / Winch Valve ?
No my transmission and transfer case has places to hook up a pto
I have a power take off but i have to get a pump possibly another power take off as i hear they are geared differently
i dont think i could sell what i have for enough money to get a new milemarker i got this setup at a good deal ill keep it and use it for something.
I couldnt imagine needing a 15 gallon tank that seems a bit much
I would apreciate some pics of your setup if nothing else to to admire it .
   / Winch Valve ? #23
I'll post a few to this thread the next time the sun comes out (should be Saturday)...
   / Winch Valve ? #24
Nice and sunny today! Here are some pics of my setup. You can't really tell from the pics, and I take no credit for the plumbing as I simply followed Milemarker's instructions, but the flow goes like this: Pump high pressure to winch in, winch out to steering box in, steering box out back to reservoir. I chose not to mount the remote connection on the winch and instead put it inside.
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
2006 Utility 3000R 53ft T/A Reefer Trailer (A51694)
2006 Utility 3000R...
2014 Ford F-550 4x4 Terex Hi-Ranger LT-40 40ft Insulated Bucket Truck (A55788)
2014 Ford F-550...
