Winches
   / Winches #11
Most everyone I know is running dual batteries. A Lot of rock crawlers also use custom alternators, set up to for higher current, AND to make power at lower RPM's. Does no good to make power at high rpm when rock crawling generally is done at relatively low rpm.
I agree 100% with what you said but around here it just hills and mud, not much rock climbing. They do have some rocks 100 miles south of here. :)
   / Winches #12
Maybe a "B" button could be added to your truck? It worked on the Mach-5 :D
Button B, Belt Tires (ベルトタイヤ Beruto Taiya?, Belt Tire): Sprouts special grip tires for traction over any kind of terrain (firm, icy, or unsteady ground; ocean floor; vertical mountainsides). At the same time, 5,000 horsepower (3,700 kW) is distributed evenly to all four wheels (1,250 hp/932.13 kW).
Mach 5: What Does This Button Do? - YouTube
   / Winches #14
I have a Vortex 12,000 lb winch on a receiver mount that I use on my truck and trailer. It's cheap, probably similar quality to the HF winches. I paid about $300 for it, new. I've had it for a couple of years now and it's been working great.
   / Winches #15
I have a Vortex 10,000 on my bumper pull trailer. It has winched on and off two tractors so far and I like it. The gearbox had a problem when delivered, but the seller took care of it. The wireless remote is great.
   / Winches #16
I have an 8000# Ramsey on my trailer for about 15 yrs now.I have used it alot. From stumps,logs to autos to tractors Still works great
   / Winches #17
I have a 3000 lb HarborFreight winch that has 6 gauge cables for the 12 volt power and calls for a 50 amp fuse or breaker. What I don't understand is when looking at full load amperage draw on 3000 lb winches they show in the neighborhood of 150 to 200 amps. The 200 amps is way more than 6 gauge wiring and/or a 50 amp fuse is rated. I understand the intermittent duty rating of devices such as winches but it looks like full load for more than a couple seconds would blow the fuse. Can someone shed some light on this?
   / Winches #18
Npalen, this chart says 6 AWG for up to 10' at 200a. Wire Gauge Amps Ratings for 12 volt Automotive Systems
Since a fuse protects the wire, 200 would be logical max (yours seems very well protected) and you could carry other fuse sizes if worse came to worse afield. (100a, etc?) It would seem the smaller the fuse you DON'T blow the less your winch has to prove, but the less you're "pushin' it" in terms of expected service life, too.
I heard the HFT 12k lb winch is quite a performer, esp for the bargain price. Even as a 'disposable' item (no reason to suggest, btw) that'd be ~3 per $1000 part....:(
   / Winches #19
Winch prices have come way down now that China is making a billion winches a year. I have at least three still in boxes (don't tell my wife) Two 2,000 lb'ers for 50 bucks each and a 10,000LB that I paid $139 dollars for, and that included a Wired remote, a wireless remote, roller fairlead and cabling. Personally I use a 7,500 lb Keeper brand on a multi-mount that goes in my Silverados front Receiver mount. For heavy pulls, I keep a Pully-block handy. The Keeper also comes with a wireless remote which is handy when pulling out a stuck tractor. I can operate the trucks winch from my Tractors seat.
   / Winches #20
Between the solenoid to winch and solenoid to battery my cables are about 21 feet in length which becomes 42 feet when figuring both positive and negative wires. The chart doesn't go that far in length but 25 feet at 50 amps calls for 8 gauge wiring. I suspect that most winches are way over-rated in pulling power and would guess that a lot of the amperage is lost as heat in the wiring.
The reason my wiring is so long is that the winch is located near the rear of a small trailer and am using the pickup battery for power. The winch is used with a cable system to dump the trailer.
Informational Lot - Financing (A56435)
Informational Lot...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A56858)
2013 International...
Jacobsen three wheeler mower (A56857)
Jacobsen three...
2014 Ford F-350 (A55973)
2014 Ford F-350...
2020 MACK P164T (A58214)
2020 MACK P164T...
