Oil & Fuel Winter Fuel Additive?
   / Winter Fuel Additive? #11
We use power service all year. We have a 330 gal diesel tank at the shop, we treat as needed. 330 gals last us 4-5 weeks.
   / Winter Fuel Additive? #12
m7040 said:
I have never used any additives for the farm tractor. The fuel supplier will use a winter blend when refilling close to winter so at least in Maryland this has not been a problem
I run a fleet of diesel trucks, generally winter blend fuel is "good enough" to keep the gel away, but we find when the temperatures fall to Sub-Zero that we see fuel lines freeze, even while the trucks are running! Power Service White Bottle is effective and what we use. I use it in my diesel tractors too. But I don't see a need for it year round. If you are going to be faced with temperatures that are regularly below 10 or 20 degrees then I would recommend using it all winter long. JMO
1993 Ingersoll Rand 185 185CFM Towable Air Compressor (A55973)
1993 Ingersoll...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2017 INTERNATIONAL DURASTAR 4400 (A58214)
2017 INTERNATIONAL...
2014 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A58018)
2014 FREIGHTLINER...
(1) Multi-Trunked Non Fruiting Olive Tree w/ Military Barrel (A59225)
(1) Multi-Trunked...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2014 Ford F-150...
