PCABE5
Platinum Member
Gotta disagree with you:
Another reason ULSD has been blamed for premature fuel system and engine wear is due to its low sulfur content. At 15 ppm (out of 1 million parts, just 15 can be sulfur), ULSD contains only a fraction of the sulfur concentration found in the previously used low-sulfur diesel (LSD), which was roughly 500 ppm. And since sulfur acts as a lubrication agent in diesel fuel, ultra-low sulfur content in ULSD is thought to be one of the main suspects in causing fuel-related problems in pre-2007 diesels, which were designed to run primarily on LSD.
I didn't start using additives for anti-gelling (always depended on the winter blends for that) That's a benefit though.
I started using additives when articles started popping up about problems resulting from ULSD in pre-2007 diesel engines. My dealer's techs have also mentioned problems with older Deere tractors with what they called "dry head" or "dry cylinder head" resulting in premature valve problems.
I would agree and disagree. Sulfur was the lubrication used in older blends of diesel fuels and nothing else was needed. Since Europe went to ULSD in the 1990's the lubrication issues were discovered well before the fuel came here to the U.S. One thing not mention is the decrease in aromatics caused seals and fuel lines to leak and fail in older diesel engines (pre-500ppm) which made failures appear greater but were not wear issues.
In 2005 ASTM came out with ASTM D975 which covered lubricity and cetane standards. This came out a year before the transition hit. This was also to make the fuel backwards compatible for older engines. But engines before the 500ppm standard (many tractors) would still have seal/fuel line issues until they were replaced with newer seals and lines. The additives for lubricity and cetane are added to the fuel by the distributors prior to it being delivered to your local fuel station. Other additives are also added to improve oxidative properties and injector cleanliness as these are problems associated with ULSD. If you buy winterized fuel you should never have to add a anti-gel agent unless your like me who still has left over summer fuel to burn before winter or add an additive to it.
One could say that you should not have to add anything to your fuel as it should be already added prior to you ever pumping it. But it can also be said that adding extra on your own will not hurt the engine or emissions. Newer engine valves, injectors and pumps are design around the ASTM standard and should provide thousands of hours of trouble free service.
