I drained my sprayers and then poured pink RV antifreeze into the tank and then pumped it through the spray lines and pump. I can see the pink antifreeze sitting in the clear plastic lines. Those lines are not easy to remove. Is it okay to leave the antifreeze in there or should I pull the lines and drain it? I know the pink rv antifreeze will freeze but supposedly doesn't expand. Its a $6,000.00 sprayer.
