wiring diagean 800 series ford 1956 needed
   / wiring diagean 800 series ford 1956 needed #11
56 800 ford won't start.New coil,battery,alternator but no fire to plugs.It sat up a couple of month.Was starting fine when i parked it last
   / wiring diagean 800 series ford 1956 needed #12
You probably should have started your very own thread, but here goes.
Ps, welcome to tbn.
Now.. You mention alternator, new coil.
I'll guess 12v.
You dont mention coil type, but ill guess true 12v as well since you don't mention a ballast resistor.
Key on, points open, should be reading 12v at coo primary.
If yes, then check points gap. .025
Make sure they open and close when cranking.
You can put a test lamp inline to coil and crank over and lamp should blink.
If yes, then check for spark at the plugs, if spark at plugs, the troubleshoot fuel. Start fluid makes trouble shooting fuel easy. If it will start and run on start fluid, but dies as soon as you quit spraying, you have a due issue.
Now, if lamp did not blink:
No lamp, check to make sure points can close and are clean, no oxide from setting up for months.
Lamp always on, make sure points are opening. If opening and you still have a solid lamp cranking, remove pigtail from condensor. If lamp goes out, condensir is shorted. Its rare, nut happens. Usual short is where the small primary wire enters the distributor from the coil, the insulator can disintegrate and short the wire to distributor case. another common fault I the copper strip from inside the distributor insulator to the points , the copper van touch the housing and short , or break and be open. Open means no lamp, short means solo lamp.
Post back with details and observations of those tests.
Hopefully it os just dirty points.
Ps if no power to coil in first test, ignition switch may be bad. Jump around it for test. Is, from, battery hot to coil.
Lastly, if you have electronic ignition, disregard this and call the ei maker for tech supt.
   / wiring diagean 800 series ford 1956 needed #13
Thank you sound guy.Will do these tests and get back to you with results.Record rainfall the past few months.There a lot of things around here that are rusty and corroded that were never before.Took all the wiring connections off and shined them up.Probably climate related because it ran fine when last used in nov.
   / wiring diagean 800 series ford 1956 needed #14
if so, check the points first before getting into all that. might just need to shine them up with an ignition hone or white or brown paper.
avoid sand paper if you can.. if you can't, after ultra ultra fine paper, then clean points with white or brown paper to clean the grit particles off.
Sanding and filing points reduces their life by removing the hard coating on them.
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A54811)
Generac Yanmar...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
LINDE WELDER (A53843)
2019 TY-CROP MANUFACTURING LTD DRY BULK TRANSPORT TRAILER (A53843)
2019 TY-CROP...
2016 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2016 FREIGHTLINER...
