hkc3
Hi, I got an old cub cadet a while back and am in process of fixing all problems, its a 12.5 hp, 38lt,hydro, i had to replace the ignition switch and thought i put all wires on corresponding plugs, no such luck, ive got it running,but its not right, ive got black hot, on B [on back of ig. switch}, ground on G, start on S, coil on M-which is grounded when key is off and open with key on, what i have left is 1 wire from safety switches--deck & blade engage, its yellow, also wire from {stator} under flywheel, all i have left on ignition switch is L which is open w/key off and gnd when key is on. Does the stator go on B to recharge batt ?, is the start wire ran through safety switches to prevent start when switches are open. Also i would like to change the hydrl oil which is old but cant find out from dealer the fill amount, the tank is full to the top which doesnt seem rite even though it drives good. Thanks for all your help.
