Dadnatron
I just purchased a back blade with 3 hydraulic cylinders. It is used and off Auction, so I haven't actually even seen it in person yet.
The blade has a diverter valve already installed directly on the blade. The previous owner only had 2 sets of connections, but 3 cylinders to operate. Apparently, rather than put the valve on his tractor, he put it directly onto the blade.
I know the basics of what I need to do, however, there are a couple things of which I am unsure.
1. Is there any good source of accurate information and instructions on the web which you would recommend?
2. I have one 'float' and one 'regular' lever. Is there a preference for which I would use/hook up to in this case?
3. Any words of wisdom which will cut down on curse words during the installation of the switch and wiring would be appreciated.
PS: Actually, I just saw an additional pic showing the switch which comes with it. It is funny, as there are a couple pics on the site NOW which were not showing up prior to the Auction. This looks like a separate switch which is likely simply hooked up to a power supply and then attached to the diverter valve.
