Won't get fooled again
   / Won't get fooled again #51
Meanwhile, back at the origial post, it is a high probability that the dealer used recommended parts and oils and service procedures. They also looked over the machinery for other issues. Like where you caught a hose on that tree stump you ran into when not paying attention. Or where you bent the drawbar while using your backblade to push that 6,000 lb rock. Or maybe where you twisted the pto shaft when the finish mower ran over your kid's bike. What about when you added those 'better' headlights and cris-crossed the battery terminals in the process?
A vast majority of self-servicers scrimp on oil, filters and wrenching. They mean well but think that TSC oil is the same as Mobil-1. Sure they can get cheap oil and parts. Sure they can remember righty-tighty and lefty-loosey, but there's a lot more to it than that. There is a big difference in oil contents that I have personnally measured as a Big-3 Powertrain engineer. Filters? You mean the ones that are practically empty or the ones that are full of sawdust and recycled paper? Detergent oil or high wax content?. Power steering fluid or hydraulic oil? Whaddaya mean there's a difference?
Just look through a cross section of this Forum of those who have stripped out their oil drain plugs, cross threaded or broken off head bolts, and can't find the 2nd fuel filter (the REAL one). Then they want to get the thing fixed on warranty because they used cheap 5wgt oil instead of straight 30 wgt. Or it was a "design" problem.
Taking into account all the incompetancies out there in Tractorville, I vote for the dealer. I want him around when its time to fix MY screwups.
$350 for a service deal sounds like a good one considering the cost of materials. BTW: As Johnny Carson used to say, Did you get a kiss with that?
   / Won't get fooled again #52
All the things you mentioned can, and have, happened at times, but I think "vast majority" should be "small minority" instead, although I reckon neither of us has any real statistics to back up our opinion.:D I think most of those who do it themselves have taken the time and made the effort to do it right.
   / Won't get fooled again #53
$350.00 sounds about right in my neck of the woods.
   / Won't get fooled again #54
That is about what my dealer charged for my 50 hour service. I use to do my own service, but can't anymore. While I don't think my dealer charged "too much", I will have one of my sons come up and do my next one as servicing these things really is pretty simple and I can show them what is needed.
   / Won't get fooled again #55
Along these lines, funny thing about human nature. We'll pay a dealer $350 to service our tractor but wouldn't think of paying the neighbor boy that can build a dragster half that much to do the same service for us. Heck No!!! Not going to pay that kid that kind of money!!! Hmmmmm...... :confused:
   / Won't get fooled again #56
If the "kid" does something wrong and breaks your tractor will he stand behind his work? Sure he may be plenty able or better than the dealers tech but when you take it to the dealer they can fix what they break on their dime.
   / Won't get fooled again #57
From the Shops point of view there should be 3 prices to every job.
$10 if I do the work
$20 if you watch me do the work
$50 if you help me do the work
$350 is about the going rate for service ihere in the south but then again most people around here either do it them selves or it just doesn't get done. (not the best option)
   / Won't get fooled again #58
That's a little bit like the shops that have the sign:
WE DO THREE KINDS OF WORK
GOOD, FAST, AND CHEAP
YOU CAN HAVE YOUR CHOICE OF ANY TWO.
   / Won't get fooled again #59
$350 is a good price in my area. I posted this on another thread, got a flyer from my dealer that wants $300 for winter servicing (changing oil + grease), plus parts, plus $60 pick up/delivery charge.
   / Won't get fooled again #60
I had the dealer do my 50 hr service and asked about it here before I did it because I was quoted about $300-350. However I had an oil leak that I wanted them to look at under warranty when it was in there. Well when I went to check it (the tractor) was in 3 pieces. It had a seal leaking in the HST. Bottom line. If I hadn't taken it in for the service I probably would have had a problem after the warranty was up. I will do all service from now on except warranty stuff.:D:D
UNUSED JCT 84" HYD GRAPPLE BUCKET (A57193)
UNUSED JCT 84" HYD...
2017 Ford F-150 Crew Cab Pickup Truck (A54814)
2017 Ford F-150...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
2020 NISSAN Versa Sedan (A53424)
2020 NISSAN Versa...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
