wont stop dying!
   / wont stop dying! #11
My tractor does the same thing what did u do to get it running
   / wont stop dying!
See its funny mine rane fine then started having the issue.i know my carbs clean and there is no trash in my gas or line. I have replaced the coil with no change. Just because im going to change the fuel out.
   / wont stop dying!
Changed out fuel today, no change...
   / wont stop dying! #14
I know you have checked and cleaned the carb but now you need to narrow down which one of the three critical items you are missing. Compression, ignition/spark or fuel.
When the engine gets hot and stalls check for spark. No spark the problem is electrical. Could be a bad plug. Check using a cold plug. Possibly non-resistor Vs resistor type also.
If you have good spark check the compression. Possible a valve needs to be adjusted causing loss of compression, but I would think you would hear this.
Check for fuel flow to the carb. Is this a gravity flow system or fuel pump system? On fuel pump systems, check the hose to the pump for weather checks or cracks. These can allow air to be sucked through the hose Vs gas from the tank.
Other possibility would be the timing shifting but this should show a weak spark.
Roy
Bomag BW 211D-3 (A47477)
Bomag BW 211D-3...
1979 MACK R MODEL (A53843)
1979 MACK R MODEL...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A52377)
2019 Allmand...
PALLET OF SCAFFOLDING (APPROX. 12 PC) (A52706)
PALLET OF...
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
