Wood chipper vs pine needles
   / Wood chipper vs pine needles #2
I chip the entire tops of loblolly pine trees with my Wallenstein BX-42. Needles haven't been an issue thus far.
   / Wood chipper vs pine needles #3
You might want to consider a chipper/shredder instead of a dedicated chipper. Chippers do well with small trunks and branches...not so hot with the small stuff.
My chipper/shredder is a Woods 5000 (same as a Crary Bearcat, since that's who makes them (Woods is a reseller only for this particular implement). It's a great machine for the typical yard or small farmette clean up work.
BTW, do let those pine branches and such set for a week or so before chipping or shredding. Once the sap has dried out, it's much easier to chip. Less sticky to handle too...
   / Wood chipper vs pine needles #4
Haven't had any issues with my Brush Bandit 250xp, a lot of machine though ! 12"- with 140 horse Cat spinning it.
   / Wood chipper vs pine needles #5
Likely not an easy thing to accept, But.. On My MacKissic Chipper shredder, I like to feed hemlock in "tip first"
That way the woody chips work to clear the needles. Sometimes a pain to get strted, but I find the side branches actually fold back and feed more readily than when shoving the but end first. Sharp knives a must!
(I burn anything over 2 inch , "limb wood is the best wood" And YES, Hemlock throws good heat when it's dry, 'just takes a good size pile of it to do so ;-)
I have no clue if this works for straight chippers.
Cheers
Cal
   / Wood chipper vs pine needles #6
Make sure the rpm is up where it's supposed to be. Some people like to run them at less than full rpms and the blower doesn't have enough air velocity which tends to clog the chute.
   / Wood chipper vs pine needles #7
I have a Wallenstein BX-42 chipper only. About 99% of my chipping is Ponderosa pine. If I don't watch the manner in which I feed; the pine pitch will heat up, coat the chute and the needles will clog the output chute. I think most of the pitch comes from the green pine tree and not the needles but the effect is the same. Two thing have helped with this situation: I got a much larger tractor (18 pto hp to 56 pto hp) and as things start looking "sticky" in the discharge chute I send 3-4 dead trees thru to clean it out. Before I figured out what was the cause it would happen every ten minuets or so - now it rarely happens. I have never tried spraying or coating the chute inside with anything. Another thing that will almost totally stop chute plugging - if you can fall the trees and let they "dry out" for a year. I have never had the chute plug when chipping only dried out pines.
I just ordered a Wallenstein BXM42 chipper-mulcher.
I an confident it will eat all my pines needles without jamming.
My tractor is a Case DX-33.
Utility Trailer (A45336)
Utility Trailer...
Sandpiper 20' Sailboat (A44502)
Sandpiper 20'...
2011 Toro 74553 Grandstand 64in Stand-On Mower (A44572)
2011 Toro 74553...
2015 Ford Taurus AWD Sedan (A44572)
2015 Ford Taurus...
2025 High Country Cargo 5x8 Enclosed Trailer, VIN # 7FWBE0818S1030896 (A44391)
2025 High Country...
2017 Ford Explorer AWD SUV (A44572)
2017 Ford Explorer...
