Wood floor over concrete?
   / Wood floor over concrete? #21
I deal with this all the time, yes first put down a thick vapor barrier (heavy plastic) on the concrete for a week or two, use good tape to hold plastic. Preferably over a heavy rainstorm. Then peel up and see if any moisture at all. If yes then you're better off with a floating vinyl type floor and wear slippers. If not, then there are many ways to go, but the 2 best options are pressure treated sleepers at 24" o.c. with a good quality low perm Ridgid foam insulation, like the blue Dow board. Then 3/4 Advantek subfloor, (it has moisture resistant glue) then tar paper then an engineered wood floor. You can get good quality engineered maple, and once installed you'll never see the difference. The other option is a multi-density foam underlayment on the concrete, you can search things like yoga or ballet dance floors or multi-density waterproof foam, then install 3/4 Advantek and then your engineered Maple floor.
Heat always goes to cold, so by keeping that moisture barrier and getting insulation under the floor, it will keep the squeaks down and toes stay warmer. If you do decide to do radiant heat you absolutely have to get insulation below the heating source or you will just lose it to the slab and dirt below.
   / Wood floor over concrete? #22
   / Wood floor over concrete? #23
And how would you adjust the existing door frames? Most doors don't have ~2.5" to spare.
The OP did not say anything about whether there were doors already framed/installed or not. However, if they were a fairly standard 6'8" door I would cut them down (or is that up?).
   / Wood floor over concrete? #24
First thing is check your moisture in your concrete as mentioned before. I saw a floor guy install hardwood over concrete once on the first floor of a house. He glued and tapconed 3/4" plywood down and then put the floor over the plywood. Most manufacturers recommend an engineered product
   / Wood floor over concrete? #25
Our climate is dry, and what works here might not in a high humidity area.
I installed our hickory T&G wood floor over a concrete floor. It has worked well for 20 years. The trick is to space the hickory off the concrete using 3/4" plywood sleepers as spacers. Also to allow a little space at the end of each sleeper. The idea is to allow for a little bit of air flow to even the humidity between the concrete. the hickory, and the room above.
rScotty
   / Wood floor over concrete? #26
Wood floor in a basement is a poor choice if your not going to allow for moisture and insulate the floor.
   / Wood floor over concrete? #27
A bunch of You Tube videos on how to install a hardwood floor on a concrete base floor.
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55788)
2016 Chevrolet...
Portable Restroom (A54865)
Portable Restroom...
2013 Ford Escape SUV (A55758)
2013 Ford Escape...
2001 BOMAG BW141AD-2 SMOOTH DBL DRUM ROLLER (A52707)
2001 BOMAG...
40' High Cube Multi-Door Container (A53316)
40' High Cube...
