wood or metal garage/shop
   / wood or metal garage/shop #11
As others have mentioned, and I myself found, when you want to insulate, and you're planning on using fiberglass and then hanging some type of board on the inside walls, you're best having studs. I essentially built a stud wall on the inside of my pole barn walls. I ended up with a nice wall, flush with the posts, but at an extra cost. My outside is vinyl with OSB under. Roof is shingles and attic is also insulated. If I had it to do again, I'd of thought ahead and built stud walls from the beginning. My opinioun is, pole construction is good for barns. If what you really want is an insulated garage, even with 10, 12, or 14 ft side walls, build stud walls. You can still use steel siding if your really hung on that as long as you use OSB under or slap on perlins.
2019 KEESTRACK K6 SCALPING SCREENER (A51246)
2019 KEESTRACK K6...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
SHOULE LN-16 LOT IDENTIFIER 119 (A53084)
SHOULE LN-16 LOT...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
