CurlyDave said:Around here we are only allowed to use single wall pipe inside a building, and it can get plenty hot in normal situations.
just curious...why is that?
Years ago I built a double barrel stove & loved it. Lined the bottom barrel 1/2 way up sides & ends with fire bricks. The 1/2 thickness ones are called 'soaps' & work best. Use high temperature refractory cement to put them togeather. It comes premixed in one gallon buckets at masonary supplies. Get barrels with removable covers & the band clamps that hold the tops on so they can be removed for cleaning/inspection and makes assembly easier. I used a horizontal baffle on both barrels to create a back & forth smoke flow to get the most heat. It will last for years if used reasonably. MikeD74Tdooleysm said:I took a load of scrap metal from building the barn to the junkyard about 2 months ago after putting in my lawn. I KNEW I should have kept that metal. The wife was getting tired of looking at it though, and I didn't have a use for it at the time.
Anyone have any experience with these barrel stoves (you convert a 55 gallon drum into a stove)? Double barrel vs. single barrel? Assembly tips?
