Item Details
- Item status
- Sold
I received the chipper new from Woodmaxx.com at the end of September 2020. It currently has 9.4 hours on the hour meter. It is in almost new condition. It includes the heavy duty Premium American Made PTO Shaft. Current (4/7/22) new price at Woodmaxx with standard shipping and sales tax is $3144. With liftgate service shipping is $3224. For sale for $2600.
It has been an excellent chipper but I no longer need it. It is very solidly built and very heavy duty with a shipping weight of 950 pounds. It requires a minimum PTO horsepower of 19. It has an 8” x 8” infeed opening. It has been kept inside except for a few summer days under a tarp. If you visit the Woodmaxx site you will find that almost all the user reviews are 5 stars out of 5.
Location: Siskiyou County, California near Oregon border.
Following are the Specs and Features copied from the Woodmaxx.com website:
– Strength in design, CNC plasma cut structural plate steel
– 19 hp. min. required
– 3 pt. hitch mount- fits category 1 or category 2 (cat-1 quick hitch)
– 8″ x 8″ In-Feed opening
– 200 lb. 24″ Diameter Flywheel (dynamically balanced)
– 2-Reversible Made in the USA fly wheel knives, 1 bed knife (anvil)
– 1120 RPM Flywheel speed
-Tachometer/ Hour meter (to ensure proper operating speed)
– Mechanical gear driven in-feed system
– Infeed rate 58 ft. /min.
– Hardened 6.25″ dia. chisel type in-feed roller
– Quick hitch Compatible (category 1 quick hitch only) (John Deere I-match/Land Pride QH10 require a special top link)
– 360 Degree swivel discharge chute
– Adjustable base legs w/ skid shoe type base
– High flow chamber ventilation
– 2″ diameter main shaft
– 3-Heavy duty cast steel main shaft bearings
– Adjustable infeed roller down pressure
– Weight 950 lbs. (shipping) Steel crate L=46″ x W=36″ x H=47″
– 8mm thick steel fly wheel housing
– Easy access fly wheel knife panel
– Adjustable bed knife (to achieve proper knife gap)
– 5 Heavy duty cogged drive belts
– Safety stop bar
– Horizontal “table height” in-feed hopper for easy loading
– Baked on powder coat finish
– Clear vinyl chip baffle
– PTO shaft included (shear bolt protected) (optional Premium shaft available)
– 3 yr. parts warranty
– Safety stop bar
