Rake Woods 8 Ft. HD Rake & Kubota L35
   / Woods 8 Ft. HD Rake & Kubota L35 #1
Keuka
Bronze Member
I've been looking for a used 7 foot wide landscape rake for my 35hp, Kubota L35. The Kubota has 4 wheel drive and the tires are foamed. I'm going to be using the rake to maintain crushed stone drives and parking areas.
I've found a used Woods LR800 that's 8 feet wide and weighs in at around 400lbs. Will that be too much rake for my 35hp tractor? I see alot of rakes with exta weight piled on and that makes me think the extra weight may be a plus.
My tractor has a catagory one, three point hitch. The guy selling the rake isn't sure if it's cat one or two and he lives 110 miles away. He said he doesn't know much about york rakes. Does anyone happen to know if it's a big pain to switch a Woods rake from cat 2 to cat one?
   / Woods 8 Ft. HD Rake & Kubota L35 #2
It is easy to change cat 2 to cat 1 or vice versa; just replace the pins.
I have a Woods 7' rake (rebadged Frontier) with my 30 HP tractor. It works fine for me but I think mine is considered a medium duty unit. It is a lot beefier than the lower priced units that I looked at but doubt that it is in the 400 lb. range.
The one annoyance with the longer blade is that I cannot reverse it on the tractor like I can with my 6' backblade, so I can't push. The landscape rake doesn't clear the rear of the tractor in the swing.
   / Woods 8 Ft. HD Rake & Kubota L35 #3
If it is a true Cat II rake, the lower pins are mounted on a wider A-frame than if it were a Cat I. That can be measured if you trust the guy that is selling it to use a tape measure. An L35 may not have the rear tread width or lift arm stabilizer adjustment to accomodate Cat I lift pins at Cat II width. An 8' rake should be no problem. If it turns out to be too wide, a torch can cut it down to size.
   / Woods 8 Ft. HD Rake & Kubota L35 #4
I run a Woods 8' rake on my NH TC29DA without problems. Jay
   / Woods 8 Ft. HD Rake & Kubota L35 #5
My LR800 has multiple pin attachments for cat II and cat I. I think you'd have no problem on a drive. Brush might be different
VERMEER NAVIGATOR S3 D10X15111 DRILL (A51406)
VERMEER NAVIGATOR...
Unused Delta Crash...
2017 JOHN DEERE 8270R LOT IDENTIFIER 176 (A53084)
2017 JOHN DEERE...
UNUSED CFG QK16R EXCAVATOR (A51247)
UNUSED CFG QK16R...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53472)
2023 NEW HOLLAND...
UNUSED CFG HANG-ON PALLET FORKS (A51248)
UNUSED CFG HANG-ON...
