Rick, where would I find the wrench that you are describing? I want to take a look at one. I may just go out and buy a 1" 11/16ths. socket and use my own breaker bar to get the nuts off. Just in case I have trouble getting them off, I may have to purchase th wrench. Thanks
Thanks Rick, I'll take a look for the wrench. Your right it should be done by dealers when they put them together. I do have some on hand. Thanks
If you already have a 3/4" breaker bar you could just get a 1-11/16th hex impact socket for $15-$20. You won't be using it very often so why pay $60.
I would use a 6 point in any case. A 12 point socket doesn't grip the sides of a nut near as well as a 6 pt.
The factory does not put never-seize on those blade bolts. Not Woods, not Bush Hog, not LandPride, nor do they claim to. It should be manditory, and every rotary cutter owner should have some available. Bush Hog makes a blade bolt wrench that fits blade nuts of all 3 mentioned brands where 1-11/16" nuts are used. The blade wrench and a large pipe wrench and maybe a cheater pipe will do a fine job on those blade bolts. Much less cost than if you have no need for the rest of a 3/4 drive set and already have a pipe wrench 18" or 24" long. Bush Hog part #6432BH should run about $60.
