woods bush hogging tips.
   / woods bush hogging tips. #1
BrettW
Platinum Member
now in S.C.!!
Yanmar FF205D
I want to start bush hogging in my woods just to make it walkable and later keep it looking nicer than brush and trees. Could use lots of safety tips. Dont want to hit stumps, rocks, or holes that would flip me.
That would really ruin my day. thanks, brett w
   / woods bush hogging tips. #2
if you have a FEL ive heard people say to put it a few inches off the ground so it will 'feel' out stumps and rocks hidden in weeds and of cource keep your eyes out
also you could walk all over it and kick about and put in posts were big rocks and stumps are so you can miss them with the hog
hope it helps
mith
   / woods bush hogging tips. #3
If possible, walk the area first.
I'm one of those guys who strongly suggests using the loader bucket as low as possible to "find" stumps and such. Now, the loader isn't going to find holes and ruts so go slow! Going slow will give you time to react if one of your wheels drops into a rut.
I also suggest you set your cutter as high as you can for the first passes over any "unknown territory". You can cut lower the next time you cut if you don't let it get too high in the interim.
Another thing is to do your initial cutting as early in the season as possible....before any growth gets going in the Spring.
You'll also have a tendency to watch the ground as you're passing and the cutter. Well, don't forget those low hanging branches that'll slap you in the face.
Again, I'll repeat it... go slow!
   / woods bush hogging tips. #4
In addition to following the advice already given above, you might want to consider some kind of guard that will protect you from whatever the rotary cutter might throw your way.
Here's a previous thread... /forums/images/graemlins/smile.gif
   / woods bush hogging tips. #5
Go around the outside of your propery clearing brush out and then catch the wind right and burn it. Should go quick and you don't have to worry about dropping into a whole or hitting a stump then.
   / woods bush hogging tips. #6
Brett: I walk the area I am going to HOG and put red flags on anything that might cause a problem especially any stumps or rocks I have not removed yet.
   / woods bush hogging tips. #7
Brett
Don't allow anyone or any pet to be on the job site. Objects can be thrown considerable distance at high velocity. A few situations that I am aware of or have heard of in this area: Rock thrown into a tree and came back to hit the oerator in the face, breaking his nose and knocking him unconscious. A piece of barbed wire was driven into the chest of an onlooker, and a picture window was broken 200+ feet away after being hit with a rock. My brother-in-law ran a large rotary cutter mounted on a Grader and had the broken nose. As I get older, I have to keep reminding myself before every job, "Take it slow and be Safe".
penokee /forums/images/graemlins/smile.gif
   / woods bush hogging tips. #8
I usually bush hog nude, with my Gravely and with my new JD. No problems yet. The Gravely hog is way out front and kicks stuff out its front end. The JD LX4 has chains on the front and kicks stuff out the unguarded rear. My hogging is all down well away and downhill of the house.
Got a looked-like-a-bullet-hole in the door of our old thick-skinned 1983 Benz driving across Alligator Alley in Florida. The contractor doing the center island was using a bush hog with missing chains and even had a hole in the deck. The cops made him take everything back to the shop. Got paid for the damage, about $1,000, and got it repaired like new. If it had been about a foot higher, I'd be a dead man. Had my pants on then.
Ralph
   / woods bush hogging tips. #9
Make sure you have the front of the hog a little lower than the rear to help avoid objects coming out the front and hitting you/tractor.
If cutting higher the first time, don't come up too high as whatever you hit will more easily be thrown toward you.
When keeping the FEL down to "feel" for objects, remember that if it hits something, you may do damage. So follow the advice given, to GO SLOW. Once you have it all cleared up, you can mow faster, but still always proceed with caution. Things just magically seem to appear in places where you thought it was clean. John
   / woods bush hogging tips. #10
sometimes you would be money ahead hiring the first brush hogging done. Let someone else tear up their stuff first, then go in behind the hired work and keep it cut.
   / woods bush hogging tips. #11
</font><font color="blue" class="small">( I usually bush hog nude, with my Gravely and with my new JD. No problems yet. )</font>
ROTFLMBO. /forums/images/graemlins/grin.gif
The only suggestion I'd add to the good advice you've already received....do your mowing in winter or early spring if possible. Not only will your visibility be improved, you will avoid mowing over active yellow jacket nests. They're no fun at all. /forums/images/graemlins/frown.gif
   / woods bush hogging tips. #13
This might seem a bit extreme to most folks, but I have used a full face motorcycle helmet at times when the hornet problem has been bad. Also great protection in the limbs and briars.
   / woods bush hogging tips. #14
</font><font color="blue" class="small">( This might seem a bit extreme to most folks, but I have used a full face motorcycle helmet at times....)</font>
Not at all. (See attachment) Been using it for years. Gerard
   / woods bush hogging tips. #15
Nice helmet. The other thing is that they are great in the cold too. I do get some laughs from some folks when operating dozers in the winter, wind blowing rain sideways or snowing. They really help, and make one heck of a hardhat. I would recommend one for any operator. I have been hit by small rocks when mowing hay when hitting mole hills. The helmet sure helps me there too.
   / woods bush hogging tips. #16
</font><font color="blue" class="small">( The other thing is that they are great in the cold too. )</font>
Sure are. Mine has vents in the chin and forehead. Great for keeping the fog off the shield. Gerard
   / woods bush hogging tips. #17
Brett,
Some great advice posted above. I learned when bush hogging high, dense stuff to use 2 wheel drive. 4 wheel drive may climb up on obstacles before you have a chance to react.
One of these days I am going to modify the bottom of my bush hog side plates so they don't skin the trees when I get too close.
John
thanks to all,
I've been too busy to get serious about it yet, but I still have plans to try it. There is so much junk in the way that It would be a major effort to get in there and start working. Right now it is garden and firewood and a barn that I need to work on. Any barn building tips? thanks, bw
   / woods bush hogging tips. #19
yellow jackets got me for the 1 st. time last year at the end of the season.they don't like bush hogs on top of their house at all and will let you know it !
   / woods bush hogging tips. #20
how do you keep the knuckle knock from happening in close turns?
Eagle Weathervane (A55853)
Eagle Weathervane...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
TUGGER TRAILER (A58214)
TUGGER TRAILER...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
