Work light wiring question
/ Work light wiring question #1
shine
Northern Colorado
Kubota B2710
I got me a couple of 35W HID work lights one for faceing foward on the rops and one faceing rearward behind the seat on the standard work light location,on my B2710. I want to have two switches off the factory work light wire thats behind the seat. Is it OK to split the wire by soldering two wires on the one hot wire going to each switch or do I need to do something differnt?
/ Work light wiring question #2
Soldering will make a good connection, cover the splice with heat shrink tubing w/ a dab of silicone in it.
Will the circuit you are taping into handle the load of 2 lights?
E/S
I think so looks like 14 gauge wire with a 20 amp fuse.
/ Work light wiring question #4
From what I have been reading on the ATV/UTV forums I would go to battery, while the HID is 35W they take a big surge when they turn on .
David Kb7uns
David Kb7uns
Thanks for the advice. Thats what I did.
Wow do these HIDs put out some serious light.
/ Work light wiring question #6
I ran a wire from battery back to an area under a cowling near the seat. to a relay. From the relay to a terminal block which merely served as a place to connect the power to the lights I installed. I ran power to the relay from the connector for the rear lights. I installed a switch in that circuit so I could control the relay with a switch and thus when power was supplied to the light. There are some other posts on the forum concerning this approach.
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
(UNUSED) REDDICK OFFSET DITCHER, 3PT (A64278)
(UNUSED) REDDICK...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A64194)
2015 Peterbilt 348...
