work on my allis g
   / work on my allis g
Yes. I just started showing them last year. So far I've taken my 1946 ford 2n, and my 1952 ford 8n to shows.
If I get this sucker done by mid march.. It's going to the starke/fl show I go to twice a year..
Soundguy
   / work on my allis g #12
Chris
With a front end like that I bet your gettin' good at standing on your head with a paint gun in your hand tryin' to get it all covered with paint.
Whiskey
That's one reason why i went with a bottom tank gun.. With the cup at least half full.. I can paint with the gun horizontal.
It does make it a tad tough.. even with the front end jacked up.
Soundguy
More updates!
I got a few hours work in on it, some before, and some after working with the animals today.
I got the front rims cad painted, and shot the front half of the tractor with another coat of paint. I pulled one rear rim and center.. buffed and primed both, and got the center painted orange.. but ran out of time to do the rim cad paint. I did some priming on the rear axle and tranny.. and am trying to touch up a repair the prev owver did on the seam in the gas tank. It doesn't leak.. but he sure used alot of sealer. I'll sand it down smooth and primer it before it gets the orange. I primed the seat.. after some buffing.. but may end up sanding on it again this weekend due to some piting. Primes cheap.. at least it will keep the metal from rusting.
I'm still waiting on one more box of parts from the big brown truck, and also have some extensive restoration to do tot he fenders and battery box.. I forsee some welding or brazing.. and lots of wire wheel and grinding.
I bought a 'test' rod to make the choke and starter pull rods. 3/16 looks great.. I;ll pick up another tomorrow. I'll heat and bend them around a 1" round stock with a little heat from the gas axe and they should look almost OEM.
Oh well, all for now.. gotta hit the shower.
Later guys!
   / work on my allis g #15
Chris:
Man your blowin' me away.......I haven't shot any primer yet and this weekend is not looking like good weather for paint or primer. I did get the hood back from a friend who did a little body work for me and have the fenders in the back of the car to drop off to him after wook and see if he can do a little repair on them and I should be on my way to painting.
The feller next door is commin' over with the backhoe on Saturday to help me clean out a drainage ditch in the back of the property, so maybe on Sunday I'll get some time to start cleaning up the tractor and preping for paint.
Whiskey
I've been lucky on weather. Even in florida, mid february is generally a tad colder.. and I don't like to / can't paint or prime in under 70' weather.. just doesn't stick good.
I've also taken an hour off work early twice this week, so I could get home and shoot some paint before dark ( SHHHH don't tell my wife! )
I actually like the body work.. the metal repair that is. The buffing and paint removal is a bit tedious though...
Soundguy
Here's a few more pics as of the 11th.
Shot of rim is after prime and center paint.. but before I broke it down to cad paint the rim which i did tonight. Tomorrow I'll reinstall it.
Soundguy
I actually had a full day to work on the G this weekend.
I finishe dup the buld of the painting, including repainting the rear cowl on the tractor. I bufffed, primed and shot the fenders, battery box, and lid, and also finished the rear rim and center. Just need to bolt those items on.. and look for areas to touch up paint.
I painted the steering wheel flat black, and went with hi-temp black on the muffler.
Looks like it will be ready for decals by next weekend hopefully.
Soundguy
   / work on my allis g #19
You sure work fast. I gather the mechanicals are all in operating order already.
Were you also going to redo the belly mower? I'll be interested to see that process.
I have an old small wagon that's rusty, but is made of sound thick metal. You've got me interested in in the process, maybe I'll start with that. Thanks for the motivational thread.
Cliff
The mechanicals are all functioning. It had been rebuilt by the prev. owner in 1992.. so that's almost a fresh engin ein antique tractor terms. No smoke, and just the lightest puff of blowby out the breather tube.. no oil inthe water/water inthe oil.. starts easy. I did attentd to a few minor mechanical and wireing issues.. but mostly maintenance items.. Funniest part was changing the fan belt.. it was ratty-tatty, and had a studebaker part number on it!
It also needed front tires.. etc.
Yes.. the mower is 100% operational, but looks like a pile of rubbish. All the spindle bearings are good as well as the mainpulley and blade carrier and ORC. The bulk of the metal is sound, and all the 'load bearing' supports are sound. There's some rust thru on the deck in a few spots I can cut and stitch, and I need to address a few splits inthe side where 'runner' rails were attatched, and the bolts loosened up and wallowed out the holes in the side of the mower.. etc. That will be my leisurely project... no rush... I've got 3 other cutters for tractors, plus a riding mower and a push mower.. so I am on 'no' timetable for the mower rebuild. However.. I have had a inkling of turning the mower into a belly mower for my 8n... it is a 60" woods mower.. I know the 8n would pull a 72".. but this would make it more agile. frame and bracketry would be easy.. I'd just need to come up with a pulley... shouldn't be too hard? /forums/images/graemlins/blush.gif I hope.
Thanks for the kind words. Something just got into me about this little tractor.. and i wanted to finish it to make at least one of the shows i attend this year.
I got about 3 hours on the G today, and got the fenders installed, removed the cobbled up battery tray the previous owner made.. cleaned up the battery and terminals, and installed the new box, and lid. My welded up new floor for the battery box fit perfectly and hold the battery good.
I opted to go with 1/8 metal dowel rods to re-create the choke pull rod and the starter pull rod that go thru the fenders. The both work great. I used a large 1.25" piece of round stock as my bending template for the finger loops. I got them as close to 'matched' as possible. if you look them over close you will see minor differences.. but what the heck.. I couldn't find originals anywhere. I had previously primed and painted the rods, so all I had to do was touch up the paint were the bend was. I installed a 6v headlamp on a cir-clamp bracket where the upright steering column support meets the steering tube. Wired it up to the OEM headlamp switch and it worked great! I thought about adding a tail lamp.. but with a quick check of the ammeter, the ignition and 30w 6v lamp draws 8.5 to 9 amps. My service manual says that genny is capable of 9.5a max.. so I'm at the limit with the single headlamp. I see pics of a small bullet style lamp inthe rear as well as a headlamp.. so my gues sis the oem headlamps must have been like 20 - 25 w instead of 3.. and the rear lamp must have been just a 5-10w red bulb.. cause the genny wouldn't do any more than that.
I mounted the last rear rim and center that I painted this weekend, and pulled the jackstands out, so she's standing on all her own rubber now.
At this point all she lacks is some touch up paint ont he lugnuts, and fender bolts, some on the headlamp bracket nut, and then decals, and then the padded orange seatcushion. Perhaps wednesday will be the 'finish' day?
In any case, I'll get some pics then, finished or not.
Soundguy
12 ft Shipping Container (A55973)
12 ft Shipping...
UNUSED FUTURE (3) AUGER SET (A57193)
UNUSED FUTURE (3)...
40ft 2-Door Shipping Container (A55851)
40ft 2-Door...
2024 John Deere 8R 410 MFWD Tractor (A53485)
2024 John Deere 8R...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
35176 (A55758)
35176 (A55758)
