Hi Junk - Sounds like you have had more than your share of problems with this stuff... something I'd like to avoid. Don't think this lady wants to put this work off until cold weather. Sounds like she'd like to "reclaim" per property and keep her kids safe this summer!Farmwithjunk said:Spray it with high concentrate of 2,4-D or Glyphosate (Round-Up) then allow it to die, and then STILL be extremely carefull. I've got bad cases of oak and ivy from logs sawed 2 years prior. The stuff lingers forever.
Wash yourself, your cloths, your equipment, and anything else that comes in contact with it in a chlorine bleach solution. Straight chlorine if you can stand it.
I've been hospitalized over poison oak 3 times. Ivy will get me but oak just about does me in. When I get it, I wash, as I mentioned, with chlorine bleach, and also I use EXTREMELY hot water. The hot water will take away the itch once you get it. That helps you to leave it alone which in turn, helps prevent further spread.
If I HAVE to deal with ivy/oak/sumac, I do so in the winter when it's not so active. That doesn't prevent you from getting it, but does lessen the exposure somewhat.
Dougster
