Working on 8N
   / Working on 8N #1
vegaome
New Martinsville, WV
1970 MF-135 and 1951 Ford 8N
Howdy Folks,
My 1951 8N won't start and I could use some advice. Its a 6 volt, positive ground, side mount distributor. The motor turns over and I have 6.2 volts all the way to the top of the coil but not to spark plugs. I took the distributor cap off and dust seal and watched the points and there was no spark.
I cleaned the points with a piece of filter box and got a spark at the points a couple times but then saw it sparking/arching under the plate the points are mounted to. So I pulled the condenser points and plate to see if the was something wrong down there. It was dirty so I cleaned it with break cleaner and lubed with blaster. I do have a new set of points handy and will put them in and see what happens.
I know I should get a manual and I will but I just wanted to ask.
Is the points gap .025 correct?
What is the proper lube for the advance weights under the plate?
Thanks and have a good evening.
v/r
Mike
   / Working on 8N #4
Side mount points are .025.
   / Working on 8N
I got spark to the plugs. Now to work on the fuel and I will have to also go back and work on the distributor. The points mounting holes and screws are getting pretty bad. Thanks fellas.
v/r
Mike
   / Working on 8N #7
a molly lube or synthetic grease is ok for the advance weights. a red n tacky hi temp is good too.
don't forget a small dab of lube on the leading edge face of the rubbing block of the points.
   / Working on 8N
Ok, thank you soundguy. The points came with a small capsule of lube and I used that on the rubbing block.
v/r
Mike
   / Working on 8N #9
you are lucky. points always used to come with cam lobe lube.. but more and more these days you don't see it anymore.
   / Working on 8N
I think I got the points at Auto Zone. The rubbing block is a brown looking phenolic looking material. I did have to elongate the mounting holes to get .025. Now I'm rebuilding the carb and its pretty rough. The carb is a TSX 33 and the idle jet is all boogered up. I have it soaking in some berrymans right now. I may have to sleep on it. I think I'm going to have to drill it out. Can you easy out them?
v/r
Mike
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
2006 INTERNATIONAL MA045 DAY CAB (A51219)
2006 INTERNATIONAL...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2019 Caterpillar 815K Articulated Compactor (A49461)
2019 Caterpillar...
1997 John Deere 8100 MFWD Tractor (A51039)
1997 John Deere...
