the old grind
Super Member
- Joined
- Jul 21, 2012
- Messages
- 5,308
- Location
- Mid-Michigan
- Tractor
- NH T-1520 HST, NH TC33DA HST, Case DX26 HST, .Terramite T5C, . NH L785
Slash, I just had to add this:
Looks like Taft MT is nearest to the portal but you rent a few miles up I90 at Lookout Pass Ski Resort and they shuttle to the portal. They pick you up over in Idaho. You can also use your own bike. The Route of the Hiawatha Scenic Bike Trail (Official Website)Nearest to what town?
As I understand it, the problem is that rail car breaks use one pneumatic hose, they lower the pressure to apply the brakes, then bump the pressure back up to release them, the hose goes through a tank on each car and so to release all the brakes the locomotive has to bring all the cars back up to pressure.I'm not understanding why brakes on a few tankers, let's say in the middle of the train, would keep a derailment from happening. If, let's say for argument sake, a rail breaks and cars start to derail 10 back from the powerhead. At normal operating speeds, all cars after the first one hits the dirt will be skidding to a stop, weather there brakes were on or not. Of course as soon as as a two cars are separated, all train brakes go on max.
There are a lot of videos that show this history accurately!Neat video of pictures of the trans continental RR building. They say is was completed in 1904 which was not accurate, it was much earlier than that in 1869. Many more accuratecys that just that.
I do understand the basic system since I worked as a carmen for years. But why these longer trains are are not being properly braked is my lack of understanding.As I understand it, the problem is that rail car breaks use one pneumatic hose, they lower the pressure to apply the brakes, then bump the pressure back up to release them, the hose goes through a tank on each car and so to release all the brakes the locomotive has to bring all the cars back up to pressure.
It takes time for the pressure drop to get from the engine back to the end of the train, the thought behind electric controlled pneumatic brakes is that all the brakes would start applying at the same time and they would all release at the same time.
The downside would be coming up with a connector that is tough enough to handle being disconnected abruptly like airlines are and easy enough to connect that it can only go in the right way and that will handle years of abuse.
Aaron Z
