Working with hydraulic hard lines - brazing
   / Working with hydraulic hard lines - brazing #11
BTW... brazing does not mean "brass". It's a thermal joining process where a molten filler material is used to join metal parts through capilary action.
Soldering and Brazing
Thermal joining processes in which the molten filler metal is drawn into a capillary gap between two closely fitting surfaces. By definition:- Soldering takes place at temperatures below 450˚C and brazing above 450˚C. Both processes occur below the melting point of the metals being joined.
Silver Brazing
Is a type of brazing using filler metals containing silver that melt between 600˚C and 900˚C. Silver soldering/Hard soldering are terms synonymous with Silver Brazing (not soldering).
Fusion Welding
A thermal joining process in which the mating faces are softened or made liquid by the application of heat or pressure or by both. Filler metal with a similar composition to the parent metal may or may not be added.
Braze or Bronze Welding
A thermal joining process using a hand torch and filler metal with a lower melting point than the parent metals. The process uses copper based filler metals melting above 850˚C and does not rely on capillary attraction.
Sure nice to learn all of this. After spending a little over 30 years, Silver Soldering (up to 1250 degrees.) Gold soldering or welding up to around 1350 degrees, Platinum at a little over 3,000 degrees.
Strange that silver is named solder, brass is named brazing rod. Gold named gold solder, & platinum named solder.
Click on the links below, first is silver, then gold, next platinum
Silver Solder Sheets | Jewelry Making Supplies - Soldering / Solders - Beading Supplies
Plumb Gold Solder Sheets | Jewelry Making Supplies - Soldering / Solders - Beading
Platinum Solders | Jewelry Making Supplies - Soldering / Solders - Beading Supplies, Tools
   / Working with hydraulic hard lines - brazing #12
the small packet left in my tool box just earned it's own spot in my garage!! WOW
We also use it for MED gas work.
2023 FORD F-250 STX (A58214)
2023 FORD F-250...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
UNUSED FUTURE HYD MINI EXCAVATOR HEDGE CUTTER (A58376)
UNUSED FUTURE HYD...
2022 RAM 2500 HEAVY DUTY (A58214)
2022 RAM 2500...
Brown Dump Wagon (A57149)
Brown Dump Wagon...
