Posthole Digger Worksaver model 500 PHD
   / Worksaver model 500 PHD #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I have a used PHD that I think is a model 500. The shaft coming out of the gear box to the auger has two holes offset 90*. The augers also have these two holes. Are they both supposed to get a 1/2" shear pin or just one? There is a sleeve around the bottom of the shaft containing the lower hole that is the ID of the auger. If I only use one pin does it matter which hole?
   / Worksaver model 500 PHD #2
2 shear pins would be used
   / Worksaver model 500 PHD #4
My worksaver PHD came with some grade 8 blots in those holes... shear pin is on the pto shaft.
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
90018 (A48082)
90018 (A48082)
Original " OLD ABE " Cast Iron Eagle Statue For Sale..www.youngsauctionil.com
Original " OLD ABE...
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
CLARK GCS20MB 4K CUSHION TIRE LPG FORKLIFT (A52472)
CLARK GCS20MB 4K...
