Worn Tie Rod Ends
   / Worn Tie Rod Ends #1
bcs001
Dahlonega, Ga
2021 Branson 3620H
I was doing my seasonal maintenance on a 3 year old 3620H and found both tie rod ends are loose at the ball coupling. Tractor has 250 hours and I have been relatively careful about not overloading the front end, turning to the stops and not turning while the tractor is stationary but they are still very loose. Talked with the dealer and found out this is only a 2 year warranty part and out of warranty for me. There is a beefed up factory replacement but they are $300+ per side which seems very over priced but not surprising in this current economic environment.
Has any one found an acceptable after market replacement that is less expensive? I know there have been a lot of broken parts probably from a combination of abuse and undersized design which is why the newer parts are beefed up. Thanks.
   / Worn Tie Rod Ends #2
Are they loose in the joint or where it goes into the steering knuckle?
There was a problem on some older 20 series but not anything recent that I am aware of. They had an updated knuckle and tie rod for those that was done under a warranty service advisory.
   / Worn Tie Rod Ends
They are loose at the ball joint not at the knuckle.
   / Worn Tie Rod Ends #4
It would take some research but if you determined the proper size for the knuckles you could cut the bad ones off and weld a replacement so it has the proper threads.
One side is left handed threads FYI. A lot of people fight getting those off thinking they both are right handed threads. Might be worth having a machine shop change the ends depending on your skills.
   / Worn Tie Rod Ends #5
It would be easier just to pay the price though. Savings may not be much after all the work.
   / Worn Tie Rod Ends
Very doable. I'm an engineer and my son is a welder.
Thanks.
   / Worn Tie Rod Ends #7
Mine have some play as well. Not the outer tie rods but inner axial ones.
After some studying of the steering geometry, it looks to me that the steering has maybe 5 to 6 mm too much stroke. This is just me guessing by eye, it could me more.
So when one turns to full lock, due to the geometry built in, the cylinder will actually pull it further than the wheel can turn and this results on pulling the knuckle with it as well. You can see it flexing, if you look closely. This, over time, will result in wear on the inner tie rod.
One of these days, I'll put the a camera and record a small video, so you can see. I did it once with my cellphone but can't get steady enough.
I know this is a relatively minor issue on my axle but my tractor is a Narrow variation of the standard model, which uses a narrow axle, different style knuckles and different tie rod setup (same parts, just shorter). I suspect the US models suffer from the same issue but can't really prove it.
Again, this is just my theory based on my observations on my tractor.
   / Worn Tie Rod Ends #8
This is my opinion as well. I love the short turning radius but that is the trade off I guess. I just try not to use it all as much as possible. But when needed it sure is nice. ;)
   / Worn Tie Rod Ends #9
Oh absolutely!! That's one of my favorite things on this tractor. I'm always in tight places and I'm always amazed how easily I can sneak it in this tight spots. Much better and easier than my old Kubota B7000 which was like a third the size of this one.
I notice this steering deal early on, so I quickly developed that muscle memory of not going to full lock unless I really need it. It's just a natural thing now.
   / Worn Tie Rod Ends #10
Careful with those loose tie rod ends. I lost one, unexpectedly as I was doing some loader work last year on a slope. It’s not pretty when one tire just buries itself against the axle and you lose complete control of steering….
I lost some sleep thinking “what if that happened at road speed near cars on the road”?
I’m thinking I wouldn’t be typing this right now if it did.
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
2001 Ford F150 (A50121)
2001 Ford F150...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
2005 KENWORTH T800 (A52472)
2005 KENWORTH T800...
2011 JACK  130BBL (A52472)
2011 JACK 130BBL...
Quick Attach EZ Axe Skid Steer Tree Shear (A52748)
Quick Attach EZ...
