worse than an Easter Egg Hunt
   / worse than an Easter Egg Hunt #11
In post #3 above I stated I reached the U joint fittings from the LEFT side, and I did. Leave it to me to be bassackward, or maybe its that I am a lefty. Rotating the shaft so that the Zerks are to the right (or to the left in my case) is the trick. Tractor with brake set, I used the start motor to bump it around to where I could feel the zerks.
This type of gun lets one guy/gal do the job:
Amazon.com: Lumax LX-1152 Black Heavy Duty Deluxe Pistol Grease Gun with 18" Flex Hose: Automotive
RawDodge, if your machine has them situated like mine; they are pointing a few degrees back and down as you reach in from under the front on each side. I had to remove the mower to reach them.
prs
   / worse than an Easter Egg Hunt #12
I might need a longer hose. Thanks Jack again for all your help.:)
UPDATE...
I went by the dealer today and they had two 4200's torn down partially. I found MY drive shaft! It sits directly underneath the radiator. The shaft is only about 6-8 inches long, but there is no chance that I'll ever get these meat hooks in that tight spot.
Now someone needs to tell me if it's worth removing the radiator to grease the darn thing. I'm sure that it is running on assembly grease because there were zerks a lot easier to get to, that never got greased. Can't imagine removing the radiator to be too difficult, good excuse to renew the coolant.
Thanks everyone for all the helpful comments, that's why I love these forums. I could go two lifetimes and not run into as many experienced owners had it not been for this forum. Long Live the internet (and may it become less expensive to use, please)
   / worse than an Easter Egg Hunt #14
Ventrac owners who performed three own maintenance & repairs should get familiar with removing the radiator. Just replacing the fan belt requires you to remove the radiator and the drive shaft. Since these machines pack a lot into a small space, it does require a few extra step sometimes to get to things, but its well worth it for all the advantages the machines have,as well as packing 30 plus hp and a hydraulic drive setup in the tiny front part of the machine.
   / worse than an Easter Egg Hunt #15
wdwurker,
Well, if your hands are a big as hams, I see two options. Go with Raw Dodge's remove the radiator route, or get yer skinny fisted woman to grease 'er fer Ya. ;-)
Raw Dodge? Have you discovered a better technique than my use of the starter motor to bump the drive shaft around to get the zerks pointing straight to the side?
prs
   / worse than an Easter Egg Hunt #16
Honestly I don't have a lot of experience performing p.m. on the Ventracs.. It seems like most of my time spent is performing repairs,because I bought a machine that was owned by ignorant ppl who didn't fix problems as they arose. I've only had mine a few years and I've only put about 100 hrs on it..I greased the drive shaft when I had the engine out. . I'm very familiar with greasing the Steiner driveshafts which are almost identical but my machines are air cooled and access to the Steiner drive shaft is much easier, without a radiator and shroud in the way. Honestly I think greasing the drive shaft is not that important unless you regularly wash the machine especially when its hot. there is very little to no offset on the drive shaft so the shaft hardly even turn if at all. I'm sure I would find a way to grease it without removing the radiator that just seems entirely counterproductive just to grease those fittings..I've got a steiner drive shaft here with about 4000 hrs on it ,it's like new,been greased maybe 5x..it's tight and smooth, I only removed it to install a different drive shaft that would meet to the Kohler engine I powered it with.
   / worse than an Easter Egg Hunt #17
I'm glad Steiner did away with the U joints and use direct drive. i doubt if i would grease them if they had them for fear of blowing the seals and causing a failure. Think about how many time you grease the drive line on your truck? Zip……. lol
   / worse than an Easter Egg Hunt #18
I was doing an oil change today and while waiting on the oil to drain I took another look at the zerks in the drive shaft. I do not think Harry Houdini could lube the front one from the RIGHT side of the tractor (left and right relative to seated driver's perspective). The manual is either WRONG or the Z model is different. With the oil change complete I went over to the LEFT side and with starter motor bumped the shaft around looking for best access to the front zerk. Again from seated driver's position, with the drive shaft rotated so that the zerk is at about 7:30 on the clock seems to be the easiest. I did it before with the zerk straight down. On the rear I could not get access with the zerks at that 7:30 position, so I bumped it again and it happened to stop with the zerk at 12:00, facing straight up, easy-peasy, just reach down through the open debris cover and there it is. Of course, mine did not need grease so soon. Actually, the factory motor oil still looked brand new; but its in a waste/return jug now.
prs
   / worse than an Easter Egg Hunt #19
Murph,
The second Zerk is about 6 inches in front of or behind the Zerk you found. The rear Zerk is under the canvas debris shield behind the radiator.
From the current Operators Manual
On the 4500K, the drive shaft can be greased
through access points in the drive shaft cover.
On the 4500P, 4500Y, and 4500Z, the front fitting
can be reached under the radiator, from the right
side of the power unit, using a grease gun with a 13
or longer rubber hose. Rotate the drive shaft so the
grease fitting is pointed directly toward the right side
of the power unit. Insert the hose from the right side,
under the hydraulic couplers and radiator, directly in
line with the grease fitting. Push the hose onto the
grease fitting and hold in place while greasing. The
rear fitting can be reached in back of the radiator,
after pulling back the canvas debris barrier.
Yes, the rear one becomes visible when you lift the canvas debris shield. The front one can be seen if it is oriented at 90 degrees (rightward) if you put your heard down near the hydraulic couplings for attachments and look a bit to the rear. It will be especially hard to see if the zerk is not clean. I suggest using prs's tips here. See also my comments here.
20' Sea Container (A47477)
20' Sea Container...
JOHN DEERE 648R LOT NUMBER 105 (A53084)
JOHN DEERE 648R...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
2017 Kia Sorento SUV (A55758)
2017 Kia Sorento...
2015 CATERPILLAR D7E LGP CRAWLER DOZER (A52707)
2015 CATERPILLAR...
