Worth the wait - 790 delivered 4/11/06
   / Worth the wait - 790 delivered 4/11/06 #11
Wow - that is a sharp tractor. I take delievery of my 790 this Friday. It is worth the wait. Good luck with it.
   / Worth the wait - 790 delivered 4/11/06 #13
Great looking tractor. What size are the front and rear tires? If yo do a lot of loader work, you might want to consider swapping the front tires from side to side. That way the track will be a few inches wider and the tire tread will still be in the correct direction. I'd also recommend loading the tires and some heavy implement or weight for the rear with the loader in use.
I know the first photo was just a photo shoot, but make sure you use the seat belt.
Also, with a post hole digger, it's possible to get them stuck because they can't be reversed, so go slowly and keep cleaning out the hole until you get the feel for the auger vs the soil. There should be some manufacturer's plate on the post hole digger unless it's really old. A check with the manufacturer eith through a dealer, by phone or the internet should tell you the HP requirements, weight, etc.
Good luck.
   / Worth the wait - 790 delivered 4/11/06 #14
Pic 3 looks like an advertisement. Very nice tractor and barn.
Cliff
   / Worth the wait - 790 delivered 4/11/06 #15
Great tractor, the 790!
I'm glad you got a ballast box...that'll help with the loader a lot!
Be safe, and enjoy that fine tractor!
BTW, my 790 has the vertical exhaust pipe. I see your's has the horizontal pipe. Where does that exit?
   / Worth the wait - 790 delivered 4/11/06 #16
Awesome looking pictures. I love the 790. Has that brute force look of a classic tractor.
   / Worth the wait - 790 delivered 4/11/06 #17
Very nice. Those are some really impressive pictures. Love the background and the different angles. Looks like something you would see in some JD literature.
</font><font color="blue" class="small">( BTW, my 790 has the vertical exhaust pipe. I see your's has the horizontal pipe. Where does that exit? )</font>
The exhaust exits just below the engine compartment on the left side. It comes straight downward out of the engine compartment and then curves forward a bit. It only sticks out a little bit and is right above the axle housing for the left front wheel.
</font><font color="blue" class="small">( Pic 3 looks like an advertisement. Very nice tractor and barn.)</font>
Thanks - That barn is actually one of my projects. It has about 1-3 feet deep of old hay on the entire floor. I'm hoping to dig it all out and get water and electricity to it this summer. It is in good shape otherwise, needs a paint job. Just trying to figure out where I am going to put all of that old hay....
   / Worth the wait - 790 delivered 4/11/06 #20
Wow--beautiful machine!
Congratulations on the new purchase!
UNUSED Safety Traffic Cones (A53117)
UNUSED Safety...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
