Would a John Deere 606 at about $600 be better than a newer brush hog?
   / Would a John Deere 606 at about $600 be better than a newer brush hog? #11
I'm going to go see it on Friday. Any simple way for a rookie to tell what is "fixed right" and what ain't?
I'm glad to hear from someone that's dealt with multiflora. I spent $65 early this spring to rent a billy goat with a 30" deck. I spent a weekend and barely made a dent in my front pastures which are almost completely free of the stuff! The back, where an individual bush might be 12' wide by 8' high AND, I don't think I've mentioned this before, on pretty hilly ground, is going to take a while to clear. (Of course, I don't have to have it done in any hurry. I'll get some time in each weekend and have it done in 3 or 4 years! ;-)
Hook it to a tractor and spin it up to speed. Does it run with minimal vibration? Does the gearbox sound "smooth"? Will it coast back to a stop without seeming to bind up? Does it LOOK like it was repaired correctly?
After a year of clearing multiflora rose off my farm, I finally relented and rented a 'dozer. Prior to that, I was using a VERY heavy duty 6' Bush Hog mower on a 67hp tractor. It was ALL that tractor wanted.
   / Would a John Deere 606 at about $600 be better than a newer brush hog? #12
I could, I guess, add a tooth bar (great idea!), but this FEL doesn't have hydraulics to tilt the bucket. It has an old, mechanical drop handle. Because of that I don't think I could use a grapple.
But with a tooth bar, I could see it catching on the bottem stems much better. Thanks.
What is the size/power of your tractor and FEL? I was somehow assuming a tractor with a modern fairly powerful FEL when I suggested using the FEL to dig them out. I can get a bush the size that you describe out of the ground pretty quickly with my tractor but the tractor/FEL weighs about 5000lbs and has a breakout capacity of over 3000lbs. It would not be worthwhile trying to dig out a big bush with an FEL that had less than 1500lbs of breakout IMO. Also, I am not dealing with multiflora rose so I don't know exactly what sort of root structure they have. I don't have any trouble with thirty foot tall, six inch diameter choke cherry and as long as the FEL is strong enough a root grapple or even tooth bar can tear up the root system pretty quickly so you can knock the bush/tree over then push/lift it out of the ground.
   / Would a John Deere 606 at about $600 be better than a newer brush hog? #13
I cleared my place with a trailer style cutter and used a chain saw and woodchipper for the +3" stuff.
With steep slopes a heavy 3pt cutter needs a heavy tractor, mine weighs in at 10K lbs.
   / Would a John Deere 606 at about $600 be better than a newer brush hog? #14
That is alot of mowing. I'd go with a heavy duty flail. You can knock down alot with that and it really pulverizes it. Heavy duty will help avoid many repairs. JMO
METAL SHELF (A47001)
Flat Bed (A47809)
Flat Bed (A47809)
Wagon Running Gear (A47809)
Wagon Running Gear...
2011 TEMPLES TRAILER SALES INC FLARE STACK (A47001)
2011 TEMPLES...
WANCO 6K LIGHT TOWER (A47001)
WANCO 6K LIGHT...
John Deere 72in Grapple (A47809)
John Deere 72in...
