Would a power beyond valve work?
   / Would a power beyond valve work? #11
If I am understanding this correctly.....You have a skid loader with only 1 auxiliary set of hydraulics controlled by the foot pedal.
And what you want is the ability to control TWO functions.......AND from TWO different locations?
IF that is correct, I really dont see an economical way of doing this without several valves or diverters, as well as check valves.
In the first post you mentioned something about valves with detent (I think you called them latching valves), but that would only give control over 1 function, and only one direction.
Input speed is limited to 900 rpm, but there is minimal inertia so I'm going to stick with a closed spool. Although it might not be required, I like the redundancy of being able to lock the motor.
KJ 7'x20' Metal Farm Driveway Gate (A53316)
KJ 7'x20' Metal...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
2012 PETERBILT 388 DAYCAB (A55745)
2012 PETERBILT 388...
2025 JMR 40in Single Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 40in...
