Would these Hydraulic cyl. work for CAT. 1 top link?
   / Would these Hydraulic cyl. work for CAT. 1 top link? #1
Von
Veteran Member, Advertiser
Western New York
Kubota B2710
I took these hydraulic cyl. off of a Unimog that I am parting out. They were used on a rail unit and would raise and lower the rail wheels. They are 2" diameter with a 10" stroke with a 1" rod with swivel ends that take a 3/4" pin, just like the top link on my Kubota. Would they be too light weight, or would they work for top links? I have four of them and have no use for them. What do you think they are worth? they were working just fine when I took them off last week.
   / Would these Hydraulic cyl. work for CAT. 1 top link? #2
Don't know why they wouldn't work. You'll need the spool of course. If you already have a rear remote then you are pretty much ready to go. It is worth a try at least. The hoses and fittings may set you back a bit.
It should be fine for a Cat 1 top link but something beefier is needed for Cat 2.
You might try posting on the Hydraulic Forum for those experts to give more (and accurate) feedback.
   / Would these Hydraulic cyl. work for CAT. 1 top link? #3
What do you want for 1 or 2 of them?
   / Would these Hydraulic cyl. work for CAT. 1 top link? #4
Another critical dimension to consider is the effective closed length; that is, center to center between each of the 3/4" pin fittings. A little too short isn't a problem with a 10" stroke, cuz I think 8" is pretty standard among Cat 1 toplinks. Too long however, and it's worthless - as a toplink. Measure the closed length of your OE manual toplink as a guide.
//greg//
They measure just under 19" long closed from pin to pin. As for price make me a offer. I would like to get rid of them, as I said I don't need that many!
   / Would these Hydraulic cyl. work for CAT. 1 top link? #6
I have a JD2720, the top link will close to about 17.5"
2025 CFG Industrial MX20R (A50123)
2025 CFG...
2015 FORD E350 16FT BOX TRUCK (A53426)
2015 FORD E350...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
TEST YOUR BID BUTTON! (A51248)
TEST YOUR BID...
2020 Can-Am Ryker Rally 900 Ace 3-Wheeled Motorcycle (A51694)
2020 Can-Am Ryker...
UNUSED WOLVERINE U-12-78W 78" LAND LEVELER (A51248)
UNUSED WOLVERINE...
