Would this be worth the 350 aud? It's a McCormick 624
   / Would this be worth the 350 aud? It's a McCormick 624 #1
Boganism
None
   / Would this be worth the 350 aud? It's a McCormick 624 #2
I have no clue what 350 aud is but other than needing new paint that tractor looks pretty decent.
350 aud is Australian dollar, since our stuff is seemingly way overpriced
   / Would this be worth the 350 aud? It's a McCormick 624 #4
Does it run? What do the fluids look like? Do you enjoy fixing things up?
   / Would this be worth the 350 aud? It's a McCormick 624 #5
If it starts then I say yes.
350 AU = $220.26 USD. The tires are worth more than that
   / Would this be worth the 350 aud? It's a McCormick 624 #6
If you enjoy restoring stuff it Definitely seems like it should be worth a lot more than $220 USA dollars.
   / Would this be worth the 350 aud? It's a McCormick 624 #7
She's stood outside for so long that the tarp has rotted right off of it. Good to see that the muffler has a cup on it...but what about the intake? If water got into the engine, it would probably need a complete rebuild. If nothing else, the value in used steel is high right now. Let us know what you do...
   / Would this be worth the 350 aud? It's a McCormick 624 #8
That looks like a Gem to restore ! It almost looks like a newer Radiator hose ? Hopefully it was not over heated ? If I had the time I think this would be a great project . Good Luck and keep the pictures coming !
   / Would this be worth the 350 aud? It's a McCormick 624 #9
Has a D206 German Diesel, used in many much newer IH tractors up to the 3230 in the 1990s.
German built tractor, solid. I can't tell from the photos, but Agri-matic versions had a clutchless shuttle/power shift unit, that may or may not work. Regular dry clutch and 8 speed box still there.
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
STORAGE FEES (A52577)
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
1995 VOLVO BM A25C 6X6 OFF ROAD WATER TRUCK (A51246)
1995 VOLVO BM A25C...
2012 STEPHENS 220BBL CRUDE OIL TRAILER (A52472)
2012 STEPHENS...
