Oh geeze. My deck is full of hydro fluid. Splashed up all over the place. Stripes on the lawn. Yuk. Still, 13 years old... I guess I can't complain too much.
I tracked it down to approximately where the lines for the steering pass back up through the frame from the engine compartment (marked with the arrow). When the tractor runs it gushes out of the bottom end of that nylon sleeve (item 70).
Do you think I'll have to drain the entire system to replace those hoses (items 30 and 40 I believe)? Will this be relatively easy, or are those lines a pain to connect up without leaks? Will I need any other parts other than 30 and 40? (I'm not sure which because the leak is within the nylon sleeve.
Thanks for any advice, pointers, cautions or encouragement.
r0gue
r0gue
