wr long elecrtic valve hookup
   / wr long elecrtic valve hookup #1
wickedinhere
Kinder, Louisiana
Kubota L2800/LA463
I got my valve kit in today and it says to hook the valve up to the power beyond port on the loader valve. My question is which one is the power beyond
port? I looked in my tractor and loader book but they didnt say what was what.
I did find where it said to implement and from implement on the tractor. I have a kubota l2800 and a la463 loader.The directions in the kit didnt have any diagrams.
   / wr long elecrtic valve hookup #2
The port on the tractor hydraulic block that says "to implement" comes from the pump and goes to the loader valve inlet.
The port on the tractor hydraulic block that says "from implement" connects to the loader valve's power beyond port. This port is probably the left port (closest to the tractor rear) on the block. Disconnect this hose where it connects to the loader valve and connect it to the WR Long valve outlet. Take the short hose from the WR Long kit and connect one end to the loader valve power beyond (where you just disconnected the hose from the block) and then the other end to the WR Long valve inlet.
Just a side note, on my Kubota/Husco valve the power beyond was connected on the top of the valve, but the only sure way to find the pb port is to trace the lines back from the hydraulic block. Also, the power beyond port on the loader valve is probably marked "P", "PB", "B", or "BYD".
Ok thanks, it might be marked but it was dark and i could see anything. I am gonna try hooking it up tomorrow.
I went and looked at the loader valve this morning and this is what i found.
The valve had a p marked on it that went to the "to implement"
The other hose was marked BY and it goes to "from implement outlet"
The last hose doesnt have any lettering on the valve but it goes to "from implement tank port"
My guess is the power beyond port is the one marked BY but i just want to make sure.
   / wr long elecrtic valve hookup #5
That is correct.
Thanks man i just got it all hooked up all i need now is for my grapple to come in.
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
2018 JOHN DEERE 672 GP (A52472)
2018 JOHN DEERE...
John Deere 6430 Side Arm Tractor (A51573)
John Deere 6430...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
