X 300 stalls after 10 minutes
   / X 300 stalls after 10 minutes #11
There are 2 coils, so if you dropped one it would still run. It could be the ECU. It is located under the top of your dash. Try tapping on it as it warms to see if it will kill or at least miss.
Thanks for all the info. I brought a plug wrench with me as soon as it quit I pulled the plugs and as I said dry as a bone. Ill try again today with a spark tester and do the same thing immediately when it quits. It has a brand new cap and the counter guy said the old cap was good but the owner bought a new cap anyway. I have a few spark testers maybe I can rig both sides up with them mow with the hood off and see if the spark dies. It seems to give ya about 2 seconds before it dies maybe not that much.
I had a problem with another X300 that wouldn't start. I disconnected the black wire that kills the coil and it started right up. I replaced the ECU and now it runs perfect. Could the ECU be killing the carbs anti backfire solenoid shutting off the gas or killing the coils? Its an expensive part to shotgun and be wrong!
   / X 300 stalls after 10 minutes #13
The ECU does control the solenoid. Anything that controls the solenoid can be an issue, if it is really a heat related issue- could point back to the ECU. Does the time extend itself with the hood off? It too is fairly common for the pick up tube in the fuel tank to get partially plugged with grass and debris which causes an intermittent stall when the pump can't overcome the debris. Pine needles and strands of grass are the worse for this. Cleaning the fuse block and switch terminals with CRC should be done anyways. I'm not sure if you are servicing mowers for living, because if you do- you should have an ECU in stock.
   / X 300 stalls after 10 minutes #14
Are these your own personal machines, acquaintances or are you working in a shop somewhere?
You really should try opening the gas cap, even if just for giggles.
Plot thickens. Mowed with it for about 40 minutes with the cowl off so I could view the spark testers when the machine shut down. Never stalled out today. Maybe the extra cooling made the difference? I know coils can fail sometimes when hot. Maybe it means nothing? Ill test again tomorrow to see if it will stall again. Ill do more with the cowl off and if it doesnt stall Ill put it back on and see what happens. Ill keep ya posted! And thanks a lot!!!!
   / X 300 stalls after 10 minutes #16
If you think it isn't air-cooling enough, check for mouse nest around the engine..
No nests or anything near cooling fins engine is really clean. Ill mow again tomorrow to see what changes.
   / X 300 stalls after 10 minutes #18
Actually you need to pull any tin, because the critters can get up inside the cowling (underneath it)
   / X 300 stalls after 10 minutes #19
Neighbor lost his engine in his Simplicity from a mouse nest.. he too thought "no way".
But cooked one cylinder. But now he is a Deere owner and very happy.
More I think about it I better pull the recoil and engine tins at the very least to rule it out. Thanks!! I never considered it because the engine looks like it came out of the show room!!! I will get back to you guys after todays cleaning and testing. Again thanks for all the help!!!!!!
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2011 FORD F-250 Crew Cab 4X4 Pickup Truck (A53422)
2011 FORD F-250...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2017 Ford F-150 (A53422)
2017 Ford F-150...
