X300 mower deck
   / X300 mower deck #1
frogfish
NE. IL
JD X300
I have a 2013 JD X300 w/ 42" deck, the new 42-in Accel Deep Mower Deck on the X330 has a mulching feature that I like. Does anyone know if the New deck will mount to the 2013 X300? thanks in advance
   / X300 mower deck #2
I've not done it though I believe it would. Check part numbers for the lift and draft arms and compare. It could be a worthwhile swap. I like the Accel deck much better than the original 42.
   / X300 mower deck
I checked with the dealer and he claims the new Accel deck will NOT fit the X300
   / X300 mower deck #4
That is odd. The undersides of the chassis seem the same between the older and later models when I service them. It may be worth to poke and prod for more info or ask another dealer. Maybe it just uses different draft arms?
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
Toyota RF1-SD1X45 4,500 LB Stand-On Electric Forklift (A59228)
Toyota RF1-SD1X45...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
