X300 won't back up
   / X300 won't back up #1
alroc06
Piedmont Triad area of North Carolina
Kioti DK 35
Hi All,
I have a 5 year old x300 that just started refusing to back up - - or backs up very slowly. Runs fine in forward. Looked in operator's manual and they only suggest seeing the dealer - - not what I was looking for.
Anybody had a similar experience? I'm guessing that the forward / reverse pedals have an interconnect, but looking for suggestions. Thanks.
Ed
   / X300 won't back up #2
This sounds like a pedal linkage adjustment issue. The lever on the transmission moves in one direction with the forward pedal, it moves the opposite way in reverse. You should be able to see if the reverse pedal is moving the lever enough, or at all.
You may also be able to reverse the tractor by pulling the forward pedal backwards. If that works, it is the linkage. There is probably something loose, and is not moving the hydrostatic control valve to the reverse position.
   / X300 won't back up #4
Best case - pedal adjustment
Worst case - Tranny is going out.
Just out of curiosity, how many hours on your X300. And can it climb a hill?
Tractrnoob,
I have about 300 hundred hours on it. It climbs hills fine - - runs great going forward. I tried adjusting the linkage, and completely understand the relationship between forward and reverse pedals. Can't seem to adjust out the slack in the reverse pedal, so it runs out of travel before it engages the trans.
Ed
   / X300 won't back up #6
That's good news. Sorry I can't be more help. Hope you get it resolved soon.
   / X300 won't back up #7
Hi All,
Ed
I'm sure you have fixed this by now, but I had a similar problem on my x530 and made this video John Deere X530 - Slow or No Reverse Fix - YouTube to show how I fixed it. Yours may be similar and as easy and cheap!
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
BELSHE DT-235 (A53843)
2017 INTERNATIONAL DURASTAR 4300 (A55745)
2017 INTERNATIONAL...
2005 Autocar WXR Heil Rear Loader Garbage Truck (A55852)
2005 Autocar WXR...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A55314)
2020 Massey...
