X310-Loud noise that sounds like hydraulic system issue
   / X310-Loud noise that sounds like hydraulic system issue
That's a good idea, so stupid for not thinking of that. I'll try it and thanks a lot.
Ok, I will do that as well as take the belt off to the transaxle and see if that helps. Thanks for the ideas and help. Will have a lot more questions soon, as I'm getting a Wheelhorse C121 going again, and a Wheelhorse 252H, as well as an old simplicity Broadmoor from the early 70's I think, but I guess that would be under a different forum for those specific brands. Have a good one and will get back with the results.
Hello everyone. It's been some time since I've been on the site, but I'm here with new information about the noise on the X310. I've taken the mower off in order to change the hydraulic fluid and filter, a little late, it's at 70 hours. Anyway while the mower was off I laid under the tractor with it running and the sound was coming from the electric clutch. I then turned the clutch on also while the mower was still off the tractor and the sound went away, returning when I turned the clutch off. My question is could it be adjusted too loose that it rattles and makes the whining noise or too tight? I've looked and it doesn't appear to be the same as older clutches with the 3 slots for checking the adjustment. Does anyone know the way to check the adjustment? I'm going to mess around with it more and may find the answer, but thought I'd check with you guys that have the knowledge. I'm also going to write a note on a X38,(I believe that's the number but have to check). I'm having a problem with it not starting and I'm sure it's electrical such as a safety switch, but would like to hear from others. Thanks for any info you can provide.
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
2016 KIMB Garbage Truck (A51692)
2016 KIMB Garbage...
100 GAL FUEL TANK AND TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
Pallet of Misc Fabrication Steel (A52384)
Pallet of Misc...
Unused 2025 MS380 Mini Track Loader Skid Steer (A51691)
Unused 2025 MS380...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
