X585 Pop and surge
   / X585 Pop and surge #11
Well, depending how big the fuel tank is, I say empty it out, flush w/ clean fuel. If you think your supply (transport) tank is dirty, put some fuel in a jar and let it settle to see if there is dirt.
Wait..... this thing doesn't have a fuel filter????? Dirty fuel "should" be filtered before getting to the injector..... /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
Actually it does. The dealer has ordered a new thottle body and will be here this week. Hopefully that fixes things.
   / X585 Pop and surge #13
I have a 2003 X585 with about 60 hours that recently started to surge intermittently. Several visits to the dealer have not located problem. Curious if anyone else has been able to locate the source of this problem.
Boy this was an old thread. I guess I should give it some closure. Don't know if this is your problem but the trottle body was the culprit. It appears that the valve was sticking or had high friction which caused the problem. No problems after they replaced it. This could be a chronic problem with the EFI throttle body or maybe a bad batch?
   / X585 Pop and surge #15
Same engine, same problem. Got worse with hours. Changed injectors, EFI controller, temp sensor specs out. Checked out throttle body, it looked ok, but didn't replace.
   / X585 Pop and surge #16
any resolution from anyone else?
thanks
Jon
   / X585 Pop and surge #17
:welcome: jon
Does this fit a problem you are having? Can you describe it for us, or just curious?
   / X585 Pop and surge #18
I am having a similar issue with my x728. I have a long thread on the other site. Basically they are tearing into te engine now at the dealer.
Jon
2015 Chevrolet Impala Sedan (A51694)
2015 Chevrolet...
2008 Cadillac DTS Sedan (A53117)
2008 Cadillac DTS...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
WINDLASS 5 HEAD (A53843)
WINDLASS 5 HEAD...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 TRUCK (A51406)
2011 INTERNATIONAL...
