x585 PTO solenoid problem
   / x585 PTO solenoid problem #1
mri4437
Rochester
John Deere cab 3720; John Deere x585
Good evening,
I am new to the forum and appreciate any input. I have a 2002 x585 with ~800 hours on it that I got used (for a great price) from a friend who moved. This winter the solenoid to engage the PTO failed and I replaced it. While this is relatively low hours, my friend stored the machine outdoors and used it to spread salt, so I assumed it was the result of corrosion. After the solenoid replacement, the machine worked perfectly.
Now, less than 50 hours of use later, the solenoid seems to have failed again. The mower will not engage. The wiring harness sends 12v to the solenoid, but when I remove the solenoid and put 12v across it, it does not actuate. This is a new JD part that was installed this winter. The PTO engagement switch, RIO switch, and wiring harness seem to test fine.
Has anyone seen this before, and is this the result of some "downstream" problem that I need to address as well? I don't want to replace this solenoid if it is the symptom rather than the cause and have it fail again soon.
Thanks for the help,
Peter
   / x585 PTO solenoid problem #2
My hood is cracked so I replace the solenoid every year. (mower is 12 years old now), I just view it as part of my yearly maintenance :) It might be that the battery is gone, my battery was showing full charge but would not start the mower last winter zapped it.
   / x585 PTO solenoid problem #3
No I haven't heard of that but it may have just been faulty from deere. I would get another and see what happens.
   / x585 PTO solenoid problem #4
Most Auto Parts Sales locations can match the old relay with a new one. May be the cheapest route.
   / x585 PTO solenoid problem #5
This is a round canister coil style solenoid I would imagine. So I wouldn't think many auto parts stores would be able to match it. I'm not saying there isn't a vehicle that uses them but I haven't seen one on a vehicle.
   / x585 PTO solenoid problem #6
Have you adjusted the air gap on your clutch? If the air gap gets to large it causes the coils to draw excessive amps which causes them to over heat and fail. There should be three or four spring loaded adjustment points on the clutch assembly. Target air gap is usually around .010" .
   / x585 PTO solenoid problem #7
Sounds like good advice...
Do you have a service manual?
   / x585 PTO solenoid problem #8
An x585 has an internal hydraulic clutch. No adjustments for the clutch. The solenoid energizes and allows oil to lock the clutch up.
   / x585 PTO solenoid problem #9
Does it look like this?
Did you replace item 1, 4 or both?
   / x585 PTO solenoid problem #10
There is a post where a X595 owner found that a simple relay was the cause.
I always keep a spare engagement switch, as a spare.
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A56438)
2019 BOBCAT T630...
2008 Freightliner Allegro Bay Class A Motorhome (A59231)
2008 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2021 CATERPILLAR...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
