J_J
Super Star Member
- Joined
- Sep 6, 2003
- Messages
- 18,952
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
One of the guys on another forum said this.
The JD455 uses a Yanmar diesel. You have an external electric fuel control valve between the tank and the injection pump. Under the seat is a safety switch that is connected to a small IC behind the dash, when that switch thinks no one is on the seat it will signal the IC to turn off the power to the fuel shutoff switch. That same IC is connected to the mower activation control switch, the PTO switch, and if you have a hydraulic option, to that too.
Another said.
Turned out to be a loose connection to the fuel shutoff valve.
Another said.
