x758 powerflo bagger blowing out grass
/ x758 powerflo bagger blowing out grass #1
jonsstihl
Quebec, Canada
just mowed my lawn for the first time with my x 758 with the power flow 3 bag bagger and I must say, I'm not impressed. there is a lot of grass blowing out the front of the deck on the right hand side.
my x 320 had an anti blowout kit I installed and it helped a lot but this 54HC deck seems to just have a bumper plate that you install on the front lip of the deck and it seems to do the same function so after spending almost 2400$ on a bagger Jd wants to get me for another $218.37 plus tax . there doesn't appear to be a kit for this I have to buy the bumpers and mounting hardware by the unit. Anyone have any experience with these bumpers M166918 and m166919
on top of this problem I think the bags I got are too big because when I hold up 80lbs of grass clippings in the bag upside down they do not fall out. the bags swell up bigger than the frame of the bags so the grass does not fall out.
the bags on my 2 bag grass catcher don't do this.
/ x758 powerflo bagger blowing out grass #2
I experienced a similar problem years ago (2003.. ) when I traded up for my x485 and put a new power flow blower to mate up with my MC419 cart. Very disappointed in the new 54C deck design as grass and leaves and clippings blew out from under the deck. There was a Deere plate that was added but little improvement.
As a result, I have quit mowing with that 54C deck and went back in time to obtain a 425 and a 455 with the older styled 54" decks. Much, much better mowing and power flow clean-up.
I'd heard that the deck design problems had been resolved, but disappointed to hear that your X758 has the similar blowout problem. I thought 12 years would have improved the design of old... but guess not.
/ x758 powerflo bagger blowing out grass #3
bags are correct....they hold more by being made that way. If they used solid material such as hard plastic the bags would not hold as much. Beats a rake doesn't it!!!!!
I think what JD did with the bags is spec the same bag for the 2 bag bagger as the 3 bag bagger but the bag frames are quite a bit smaller on the 3 bag than on the 2 bag bagger. I tried looking up part numbers for the bags but couldn't find anything
I am really happy with the pick up performance of my x320 with the 48c deck and 2 bag bagger. But it is easy to tell that the 3 bag hopper is a much more industrial hopper as opposed to the 2 bag hopper which is a more residential unit. he way the 54hc deck is made is the problem. the front lip is about an inch above the sides of the mower so the air blows out of the gap instead of going into the blower. Installing the bumpers seem like it would help in theory but JD really should have included it in the bagger kit.
It sure does beat a rake especially when there are lots of leaves down but at this time of the year there are only a few sparse leaves down and with my current setup I am only picking up grass clippings. the few leaves that are on the ground just get blown out the front.
/ x758 powerflo bagger blowing out grass #5
I only use mine for leaves. I let the clippings drop to fertilize the lawn. The only baffle that I have came with the Powerflow. The long one that mounts under the deck to funnel to the narrow opening on the blower.
The 54HC deck must be different because I didn't get a long baffle to mount under the deck.
/ x758 powerflo bagger blowing out grass #7
James,
What type of blades are you using? When I was setting up my power flow blower I remember reading that Deere recommends using standard blades rather than high lift bagger blades. Less turbulence would be better in your case. Since the blower is downstream from the deck it should create a slight vacuum, so you should not have it pushing leaves ahead of the deck.
After using the bags on my previous mower I went for the MC519 cart and it is much easier and faster to dump.
/ x758 powerflo bagger blowing out grass #8
Especially easy to dump with a hyd. ram in place of the gas lift assist cylinder that the cart comes with.
/ x758 powerflo bagger blowing out grass #9
Here is a pic of my X485 with 54c deck and MC519 cart, leaving many leaves still on the ground. They were not the hi-lift blades and the deck did have an added plate bolted under the leading edge. The 445 or 425 with the 54 deck left the ground clean of leaves.
/ x758 powerflo bagger blowing out grass #10
Beenthere,
I use the 48" with the MC 519 on the x749. So must be the deck design as you mention.
/ x758 powerflo bagger blowing out grass #11
If the deck isn't leveled properly, I.E. the back is level with or lower than the front, it can cause blowout from the front of the deck. The back of the blade tip should be 1/8-1/4" higher than the front if I remember correctly.
the blades are brand new standard blades. The guy I bought it from was using standard blades with a mulch kit but he must have hit a rock or something because the baffle was bent and the blade running in the bent area was tweaked.
I leveled the deck once, mowed my lawn without the bagger, then I installed the bagger and leveled the deck again. the front of the deck is currently about 1/8 inch lower than the back.
I really think it is the design of the deck. The front lip is higher than the tip of the blades. JD markets this as an advantage when you are cutting tall grass. But evidently it does not help with the bagger installed.
tonight I should be able to get around to mowing my lawn a second time with the bagger and I will drop the mower down 1/2 inch because I had it set at 3" cutting height last time and that seemed a little tall. I hope that will help.
/ x758 powerflo bagger blowing out grass #13
When the deck design was changed from the older 400 series 54's (around 2002 ) to the 54C, they appeared to go to a boxier-style, more-robust appearance and I believe shortchanged the flow of cut grass beneath. Certainly they were aware of the problem at Horicon plant and tried to cover the new design with patchwork by adding plates to the underside. Another design change that was so expensive to convert their huge press molds over to the new that they couldn't go back. Unfortunate how those decisions are made in corporations that get out the door and no underling engineer can correct it. Much like big government.
My decks are leveled properly with the correct fore and aft 1/8 - 1/4" drop in the blade tips.
That 54C deck has been stored away for the last 10 years and will only go with the X485 if/when it is sold.
well I broke down and bought the bumpers and installed them but at 280$ with 15% tax included they are quite expensive.
They do make a noticeable difference in how much leaves stay under the mower. It is still not perfect and not as good as my old x320 with the 48c mower. I am happy about the results because there is a significant improvement but I still don't think I should have to buy it. It should have been included in the kit.
easy to install all I had to do was notch the blower housing so that it would slide into the mower. They bolt onto the lip of the mower with these special clips so there are no holes to drill.
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
Kubota L4701 (A53317)
TANK MANIFOLD (A58214)
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
(1) 48"X8' ADS DRAINAGE PIPE (A60432)
(1) 48"X8' ADS...
