cwbyeng1300
Bronze Member
- Joined
- Apr 16, 2020
- Messages
- 55
- Tractor
- John Deere
If your right hand cylinder seals are bad the fluid is bypassing pressure internally in the cylinder. Could be the issue. Test it by raising the FEL a foot or so from the ground, remove hoses on the suspect cyinder & plug both ports & the hoses. The you can lower the FEL (not running the engine). If it lowers down then you know the cylinder is bypassing.
