xr4145 broken hub
   / xr4145 broken hub #1
Jaymeduty
Bigfork, Mt
XR4145HC
The front left hub on my xr4145 broke today while turning with a heavy pallet of compost on the forks. Does anyone have a parts diagram, i need to order parts and get this back together asap.
Thanks for your help
Jayme
   / xr4145 broken hub #2
No parts diagram. I lost a bearing which ate everything in the hub on the right front of my 4155. No assembled hub available even though there was a part number for it. (don't recall the part number).
I ordered the individual parts through LS and New Holland and assembled it myself. I think I was 2 weeks with NH. LS eventually called with some of the parts a month or so later. I think I dropped $1100 on the parts.
New Holland was happy to print me a diagram. That was about 1 year ago. No idea where that diagram is now.
   / xr4145 broken hub
I got all the parts to rebuild it and found the diagram of how the parts go, now i have three questions.
Does the ring gear or the axel seal need to be pressed on?
What should the axel nut be torqued to?
What do the 8 bolts that bolt the axel assembly to the axel housing get torqued to?
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
2008 FREIGHTLINER B2 BUS CHASSIS (A51222)
2008 FREIGHTLINER...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
Agco 8200 Flex Grain Platform (A50514)
Agco 8200 Flex...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
