Yanmar 2200 Wireing Diagram
   / Yanmar 2200 Wireing Diagram #1
wildthang4786
Mantachie, MS
YM2200
Hello everyone! I'm new to these forums and also a new owner of a yanmar 2200. I'm needing a little help and hope someone can help me out. The wireing on this tractor is pretty much messed up, it does run fine as I have done used it and stuff, just I don't have any lights of any kind, and there is a lot of wires just hanging down under the dash that doesn't go anywhere, as in broke, cut, etc. The fuse panel "box" looks like it is pretty well toast and busted. Most of the knobs don't work, thankfully the key switch does! Everything else is in great shape and looks and runs fine. So my question is, does anyone have a wireing diagram for this tractor or one pretty close to it to go by so I can re-wire it back to the way it was or wire it my own way and add new switches and lights etc. myself? I found one on here but it has many more dash lights and switches/gauges than my tractor has (or has now!). I'm good at the wireing part, just don't know what goes where and don't wanna mess something up. Far as I know everything mechanical does work fine and I "think" the regulator is ok, will know more about that when I get some of this wire mess fixed! Thanks for any help I do recieve in advance! /forums/images/graemlins/cool.gif
   / Yanmar 2200 Wireing Diagram #2
Here is a YM240 schematic, (thanks to California), that should be close enough.
Thanks! I'll give it a try and see how far I get.
Another question, this really don't fit my topic, but does anyone know where to buy the suitcase weights for these? I need at least 150# would be nice. Thanks
   / Yanmar 2200 Wireing Diagram #4
Any "real" tractor dealer should have them, they are pretty much generic. Expect to pay about 1$ per pound.
   / Yanmar 2200 Wireing Diagram #5
There are some old threads on here about replacing the fuse boxes.. I think you can get a generic at any auto parts.. There are threads about replacing the voltage regulator with a modern electronic one. I would recommend these changes and then you can just wire the rest how ever you like.....but u will need to know which amp fuse to use where....
   / Yanmar 2200 Wireing Diagram #6
Like this from NAPA.............
   / Yanmar 2200 Wireing Diagram #7
Is that picture title the item part #?
I like that one better than autozones!
Another question, does anyone know if the Wells VR728 regualtor will work with my tractor?? (YM2200) Or will it require a little "modifying"??
   / Yanmar 2200 Wireing Diagram #9
No
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
UNUSED RAYTREE REDM32-32" EXCAVATOR DRUM MULCHER (A51248)
UNUSED RAYTREE...
2018 John Deere R4038 Sprayer (A53342)
2018 John Deere...
MANTIS 155B LOT NUMBER 230 (A53084)
MANTIS 155B LOT...
Komatsu 330 Excavator (A51573)
Komatsu 330...
New/Unused Quick Attach Post Driver (A51573)
New/Unused Quick...
