/ Yanmar 2610 won't start and I believe all the air has been bled out of the injection system why
#1
The manual for my Yanmars says bleed first at the filter inlet bleeder screw, then the filter outlet bleeder screw, then at the screw down on the injector pump inlet fitting. And a couple of old-time Yanmar dealers on here posted that there is never a need to bleed at the injectors.Changed fuel filter bled all the Air lines out of the system because I believe I got air in the injection lines still will not start
You need to loosen injector line at the injector, one at a time, crank until solid stream of fuel, tighten, do the rest one at a time.Changed fuel filter bled all the Air lines out of the system because I believe I got air in the injection lines still will not start
