Yanmar 3110D oil type and capacity?
   / Yanmar 3110D oil type and capacity? #11
Mine has the ROPS and PTO shield on it as well as the loader frame. Here is a picture of it before I took the bubble wrap off the ROPS.
Sweet. You got a refub unit that's more like a restore. You must be out west because those machines are badged YNM and the V-loaders are made in Vietnam.
Did you get a loader manual for the machine. It would help down the road for getting replacement pins and seals.
Yes, sorry I didn't update my profile with where I am at but I am in NW Montana and I got the tractor from a refurb/restore place out of Idaho. I'll update my profile as soon as I figure out how to do so. I got the manual for the hydraulic joystick later on when I needed to fix it last year but I don't have the manual for the loader frame. I wish I did because I want to make a manure bucket for it and I need the specs on the quick detach stuff on the frame so I can make the brackets that will get welded to the bucket. First things first I need to oil change the tractor and then I need to change the hydraulic fluid again before winter because whatever they used when they rebuilt it gets thicker in winter here than it should. It still works but I worry about wrecking something so i am going to switch it with a J20D Napa equivalent full synthetic before end of Oct when we usually get our first staying snows.
   / Yanmar 3110D oil type and capacity? #13
In WI, we see temps down to -22F, so J20D is helpful. J20C could work that low, just a bit slower. Over in the Ukraine, Russia and other Eastern EU countries, Mopar ATF+4 is easy to get, but not the J20C or D. So, people end up using that instead.
Unused Delta Crash...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2017 Takeuchi TL8 (A47477)
2017 Takeuchi TL8...
91013 (A48082)
91013 (A48082)
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
