Yanmar F16d ring and pinion
   / Yanmar F16d ring and pinion #11
No accessories came with it. if it had a loader then that would shed a different outlook on the worth..
the bad ring and pinion gear was already removed by the seller but they put back the axle as a front two wheel drive
PS then the seller sent the gears to Chattanooga,tn to a shop guy who then lost the old gears
   / Yanmar F16d ring and pinion #12
The old saying "your between a rock and a hard place" may apply here. I wish you the best with what ever you decide.
   / Yanmar F16d ring and pinion #13
NOt sure the exact size of it but i assume its a 16HP tractor at the pto...or similar size to the old 1500 and its got more of an auto transmission type.
I would think you could get $2000-2500 for it.
But like winston said its parts are worth well more than that.
The Ring gear set is easy $500 used!!!
Engine $500-800 easy id thing...tires are $300 with the rims easy i would think depending upon condidtion. trans section i think could bring $1500 alone with the good ring gear. The more you part out the more that money would come back.
And what i should of made clear on my earlier post is that $350 for the chevy ring set was an aftermarket and one of the cheaper ones. If i would of bought a big name set or gone to the delater your closer to the $500 mark which is not that far off of you and like i said thats for a common rear end in a pickup truck.
   / Yanmar F16d ring and pinion #14
I paid $ 800.00 for the tractor and if I add $750.00 thats $1,550.00 that I would have in the Yanmar F16D 4X4
is that top on what that tractor would bring ?
No accessories came with the tractor
Your tractor is worth $5000 in good running condition.
   / Yanmar F16d ring and pinion #15
I think I saw that one on Craigslist. I decided to pass on it because it was not the line of yanmars that I like. Good luck with the fix. I think it is worth it to buy the gears if you need a tractor.
   / Yanmar F16d ring and pinion #16
A 4wd Yanmar is generally worth about $1000 more than the same 2wd model.
CASE 610 Sprayer System 2000 Gallons (A56436)
CASE 610 Sprayer...
LANDPRIDE FDR1660 5' FINISHING MOWER (A58375)
LANDPRIDE FDR1660...
EquipmentDealz (Shipping Terms and Instructions) (A59213)
EquipmentDealz...
UNUSED FUTURE SG45 HYD STUMP GRINDER (A58376)
UNUSED FUTURE SG45...
(2) 10 LUG (A58376)
(2) 10 LUG (A58376)
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58216)
SEMI AUTOMATIC...
